Re: Packing bearings...how? #495070 08/30/04 04:13 AM
ArbitraryNotion Offline
Muffler bearings go out quite a bit and need servicing... might want to search for those also... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Packing bearings...how? [Re: VAHunter17] #495071 08/30/04 04:49 AM
4
4xGeek Offline
Damn... Y'all are harsh over here! <img src="/forums/images/graemlins/lol.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Packing bearings...how? [Re: ArbitraryNotion] #495072 08/30/04 04:49 AM
dogwater Offline
Don't forget to check your blinker fluid, also! <img src="/forums/images/graemlins/pfft.gif" alt="" />
Yeah, a glob of high-temp grease in your clean palm and whack, scrape, turn, repeat...
Re: Packing bearings...how? #495073 08/30/04 05:22 AM
OOP'S Offline
raise vehicle, tire off, hub off, 2 lock nuts and a spacer and a lock washer, may wanna take brake caliper off if you wanna remove the rotor, pack bearing put it back together
good luck
dave
You forgot two things:
1. If you want to pack both front wheel bearings (and who would only do the outboard bearing) you need to get a new inner seal and you have to take the caliper off!!!
2. Clean the bearing in a solvent cleaner before re-packing!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Packing bearings...how? #495074 08/30/04 09:25 PM
VAHunter17 Offline OP
<img src="/forums/images/graemlins/butwiggle.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
'98 Tacoma TRD ext.cab 2.7 5spd 6inFabtech sus w/ 33x12.5.15 TrxusSTS on 15x10 DC-1 (Black)
'90 4Runner 3.0auto stock as of now
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6102 MB (Peak: 0.6908 MB) Data Comp: Off Server Time: 2026-06-21 11:11:11 UTC
