Sticking Caliper #43945 11/29/02 08:45 AM
Bonzai Offline OP
I noticed that my drivers side caliper is not releasing when the pedal is released. If tapped it will mostly release. Couldn't check the pass side, but will in the morning. If both are sticking, is this bad calipers or can something else in the system be causing this? It is an '89 Toy p/u with a SAS and '83 front axle.
Thanks,
Taylor
89 Toyota P/U, 22re, SAS, 4" All-Pro Fronts, Chevy rears, 33x12.50's...
Re: Sticking Caliper #43946 11/30/02 06:50 AM
it's the caliper/pisons/seals
if you take it apart you'll find rust/dirt and see why it sticks
rebuild or replace
the other wheel and master cylinders are suspect
including the clutch by logic
Re: Sticking Caliper #43947 11/29/02 07:11 PM
OOP'S Offline
When was the last time that you completely flushed your brake fluid in your system? It is recommended every 1-2 years. Brake fluid absorbs water from the atmosphere so if you live in a high humidity area it should be done once a year. How many of us do this? Not me!!!!!! <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
<small>[ November 29, 2002, 01:11 PM: Message edited by: OOP'S ]</small>
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Sticking Caliper #43948 11/29/02 10:33 PM
Bonzai Offline OP
Thanks to both for your help!
It was sticking and I am going to replace both calipers in the morning and do a complete flush of the sytem.
Re: Sticking Caliper #43949 11/29/02 10:37 PM
RWD Offline
Many times the rubber boot that protects the caliper pistons will tear and allow moisture in. This can cause the pistons to become pitted. Eventually the pistons hang and do exactly what you are describing. I had this happen on both front calipers on my 93 T100 at about the 7 year point. Bob
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.007s) Memory: 0.6038 MB (Peak: 0.6631 MB) Data Comp: Off Server Time: 2026-11-16 01:21:51 UTC
