2wd & 4wd differences
#496379
09/01/04 01:30 AM
other that the extra hole in the tunnel for the transfer case shifter, are there any physical differences between 3rd gen 2wd and 4wd cabs? how about beds? thx.
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: 2wd & 4wd differences
[Re: dildinon]
#496380
09/01/04 02:40 AM
I know the flare of the fenders is much less on 2wd trucks. More than likely stock 31" tires would rub on a 2wd body.
[Re: dildinon]
#496381
09/01/04 02:48 AM
i know of a difference in the fender flare, 4wd bigger and wider to alow the bigger tire(duh, yes i know). i know of a few lowrider id-jits that swapped in the 4wd beds so they could tuck a bigger set of rims and lower the truck more.
i dont know of any thing else
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested. 06 CRF450R one mean roost flinging machine
[Re: rednekbean]
#496382
09/01/04 03:07 AM
Very little is different other than the suspension. Here is a lifted 2wd and a 4wd. Just looking at them, you can hardly see the difference. ![[Linked Image]](http://dana.ucc.nau.edu/~jec56/2wd/far.jpg)
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
[Re: dildinon]
#496383
09/01/04 03:20 PM
Don't know about 3rd gen, but on 1st and 2nd they're the same except for the fender flare at the wheel opening as stated above, and the hole for the t-case shifter. Everything else is the same and interchangeable.
1st and 2 gen beds also have the same mounting bolt pattern.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 - '84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
[Re: ArbitraryNotion]
#496384
09/01/04 09:49 PM
Hey ArbitraryNotion, how did you lift the front of the 2wd?
1985 Toyota Pickup 5.29's Rear Spool Dual Cases 35" BFG MTs
[Re: Terrys_85_Toy]
#496385
09/01/04 10:15 PM
i think he cranked the torsion bars, and the rest is from a body lift
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#496386
09/01/04 11:26 PM
Its a fabtech 3.5in lift kit, 2in RB body lift, 33x15x12.5in tires and 4wd shocks. Its also got 4.30 gears. 2wd trannies aren't geared like 4wd so 4.30 matches 33's.
Josh
[Re: dildinon]
#496387
09/02/04 01:48 AM
The difference between the 2wd and 4wd third gen(84-88) trucks are bigger wider front fenders, different bumper end caps, and the bed wheel wells are also wider/more square on the 4x4's, everything else is the same. You can use the 2wd fenders and beds on 4x's if you cut the fenders and run a set of bushwacker fender flares.
[Re: Snowtoy]
#496388
09/02/04 06:05 AM
The difference between the 2wd and 4wd third gen(84-88) trucks third gens are 89-95
Davin Nisser
