Should I go with 31's or stick with 30's?
#496737
09/01/04 08:54 PM
Well, my 30x9.5-15 mud tires from Hi-Tec Retreading are getting old and tired. Get it, tired? haha...
I am going on a road trip soon so I think I'm gonna get new tires. I am currently running 30's with about a 3.5 inch spring lift and 1.5 inch body lift, and 1 inch Spidertrax wheel spacers to space out the rims 1 inch. There looks to be plenty of room for 31's, that's not the issue, the issue is power loss.
Do you think there will be a noticeable power loss going from 30's to 31's?
Thanks for any advice.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Should I go with 31's or stick with 30's?
[Re: Nukeiridium]
#496738
09/01/04 09:42 PM
I doubt you will notice much of a difference at all between the two.
Later... Joe R. 97 Kia Sportage - Eibach 2 lift , 30" A/T's, Warn manual hubs Hi-Lift, GPS.
[Re: Nukeiridium]
#496739
09/02/04 02:14 AM
I run 30" ATs in the summer and 31" MTs in the winter and the power differance is more than you would think for just a 1" increase. I still think the power with the 31s is livable enough that when my 30s ware out I will replace them with 31s. Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
[Re: DennisThompson]
#496740
09/02/04 02:20 PM
I ran 31x12.5 Boggers & found my 5th gear to be useless. The added ground clearance was nice, but with a tire that wide alot of trimming was nessasary. Even trimming the fenders back even with the rocker panel would still rub the fender. At that time I had about 4" of suspension lift & 1 1/2 body lift. If ya go with 31's do not go as wide as I did. http://img.photobucket.com/albums/v336/rockfreek/Rokia/MVC-030S.jpgThis photo is before the SAS with those tires
Why go around? When You can go over!
[Re: KIAFREEKROB]
#496741
09/02/04 03:06 PM
arer you kidding, go with the biggest tire you can possibly fit, always. if that is the 31, go for it, if not, get the 30.
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
[Re: Dave Scott]
#496742
09/02/04 05:07 PM
With the lift you got, you should have NO problem with 31/10-50's. You'll get a little rubbing on the rear shock, but you get that anyway with the stock tires. I eliminated the rub by removing the cover of the shock with a grinder.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
[Re: maraguez]
#496743
09/03/04 09:21 AM
My wheels are space out an inch farther than stock so I might not rub on that shock. Here you can see that I have some room to spare with the 30's: ![[Linked Image]](http://cleedo.com/sportage1.jpg)
[Re: Nukeiridium]
#496744
09/03/04 01:30 PM
i recommend at least a 32, maybe even a 33, as long as the cost is not prohibitive. you have plenty of room for it, except you may need to trim a couple small areas where they'll rub- back side of front fenders, firewall seam, etc.
[Re: Dave Scott]
#496745
09/03/04 01:44 PM
I'd love to get some 32's or maybe 33-9/50's(less trimming needed), but I worry about the gas milleage, I travel to Mexico a lot with the gas there at $2.50, also the rear differential bearings tend to go faster when you get bigger tires, and finally, these darn BFG TKO's, lasts for ever. Maybe I should just go crazy one day and get those 33's.
[Re: maraguez]
#496746
09/03/04 08:52 PM
Well, too late for second thoughts now, I pulled the trigger! The 31's are ordered and on their way! I got the Hi-Tec Retreads OTR Mud tires with their exclusive Green Diamond embedded carbide crystals (not available anywhere else in the USA). The green diamonds will help a lot with the slick roads we get during monsoon season, as well as making driving on ice easier when I go North to the snow. I'm excited! These Green Diamond things seem to be a great invention, and are known to actually make the tire last longer too. They can be used year-round with no ill effects, and they work about as well as studs when driving on ice, according to testimonials I have read. I especially like the idea considering how these tires are mud tires so they have less surface area contacting the pavement. Hi-Tec Retreading is the only place you can get Green Diamond tires in the USA. If you live anywhere with slippery roads, you should read about this product: http://www.high-tec-retreading.com/diamond.html
