Propane tank bracket???
#498677
09/07/04 03:13 PM
Anybody ever see a bracket for the 11 pound propane tanks? I would like to mount mine on the tire carrier of the Rodeo. I can probably make one at work, but if the was a general one that I could use as is or modify slightly it would save me some time. Thanks!!!
George <img src="/forums/images/graemlins/nana.gif" alt="" /> 92 Rodeo XS 4x4 HomePage
Re: Propane tank bracket???
[Re: RodeoXS]
#498678
09/08/04 02:30 PM
BTT...
Anybody? I know this isn't a common thing but thought maybe someone here into camping might know. Curtis J has all these mounts and brackets he dreamed up and was hoping maybe someone had an idea. Thanks.
George
[Re: RodeoXS]
#498679
09/08/04 02:39 PM
Go with a forklift style tank, you should have plenty of mounting options then, just google... ![[Linked Image]](http://www.internetimage.ca/hn/images/39.jpg) IMHO, i'm not sure the rear tire carrier is the safest place to mount a propane tank. -Rob
[Re: RobG]
#498680
09/08/04 05:27 PM
-Rob
I understand, but I figured it was no worse than gas cans back there.
[Re: RodeoXS]
#498681
09/08/04 05:30 PM
Gas in a can will just pur out unless it finds a spark or heat source. Propane tank will go boom if hit in the right spot or hard.
Later, Daniel
"Thanks for the joy that you gave to me"
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6065 MB (Peak: 0.6719 MB) Data Comp: Off Server Time: 2026-07-14 12:26:58 UTCValid HTML 5 and Valid CSS
