2.85 and PTO ? #498830 09/08/04 12:07 AM
Nitteberg Offline OP
I need to now if it's possible to make a gear kit to the pto, so it will fit the 2.85 gears or I have to sell it <img src="/forums/images/graemlins/angry.gif" alt="" />
http://nitteberg.com
-83 Pajero SWB Soft Top 2,3TD
35x14,5x15 PitBull Rocker
Bodylift, LSD, PTO-winch, Intercooler, 2.85 gear's
Gen2 upper a-arms, flipped and raised ball
Re: 2.85 and PTO ? [Re: Nitteberg] #498831 09/08/04 01:47 AM
That would be a drag to loose the PTO...
Re: 2.85 and PTO ? [Re: Nitteberg] #498832 09/08/04 02:08 AM
Nitte, is the gear the pto engages with in the transfer case smaller or larger? If the t/case gear is larger, you could get a spacer made to move the pto gear further from the t/case gear so they line up again. If you have a smaller t/case gear, I'd guess you'd have to find a pto that matches.
How much do you want for it?
Re: 2.85 and PTO ? [Re: fasteddy] #498833 09/09/04 10:40 PM
It's larger and a spacer is no problem, but the teeth are diffrent and will make sound and finaly brakedown I guess.
Re: 2.85 and PTO ? [Re: Nitteberg] #498834 09/25/05 10:47 PM
The problem is solved, with new one off gear set from Australia, not cheap, but worth it. Nice to pull car's with overheated el.winch out smile
http://www.offroad.no/snitz/topic.asp?TOPIC_ID=38579&whichpage=2
Re: 2.85 and PTO ? [Re: Nitteberg] #498835 09/26/05 12:02 AM
StockRaider Offline
can I be so ignorant to ask how you install a PTO winch on a SWB Pajero/Montero/Raider?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 2.85 and PTO ? [Re: Nitteberg] #498836 09/26/05 12:02 AM
W
wyleone Offline
Thankyou Nitteberg, I will keep and enjoy that picture. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 2.85 and PTO ? [Re: StockRaider] #498837 09/26/05 01:21 AM
sparkem Offline
His was factory.
Re: 2.85 and PTO ? [Re: sparkem] #498838 09/26/05 01:56 AM
W
wyleone Offline
His was factory.
Oh yea, you need to find some of his action shots, His is nearly a "stockraider-Pajero" and it will leave you drooling. <img src="/forums/images/graemlins/drunk.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6268 MB (Peak: 0.7292 MB) Data Comp: Off Server Time: 2026-11-02 22:34:32 UTC
