can i get new gears?
#499401
09/09/04 03:32 AM
i've been searching around the net, but can't find if anyone makes new differential gears for my truck. i have a 1995 toyota t100, 4wd, with the 3.4l. i have a four inch suspension lift on it with 33 inch bfg at. i noticed a bit of power lost after i put on the 33's. and now i want to put on a body lift and some 36's. so i was wanting to regear the truck. but couldn't find anything on it. does the t100 have a different axle than all the other toyotas? because i can seem to find gears for everything else but the t100. any help would be greatly appreciated.
Re: can i get new gears?
[Re: gentouteg]
#499402
09/09/04 05:32 AM
Welcome to the board<img src="/forums/images/graemlins/cheers.gif" alt="" /> Our T100's have a 8 1/4" gear set. Same as the tundra, sequoia and the non-trd tacoma. Good luck <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: gentouteg]
#499403
09/09/04 07:03 AM
Call Randy's, they'll get ya all hooked up. I run 4.88s & 36s and find the gearing close to stock. Much bigger and 5.29s might be in order.
Did I hear somewhere that there's going to be a Dana 5.29?
~Adam  96 T100: D44, lockers and stuff
[Re: adam]
#499404
09/09/04 06:11 PM
Toyota Moderator
The rear gears in a T100 are the same as a Tundra. The front gears are the same as '86-95 Toyota trucks/4runners. http://home.4x4wire.com/erik/diffs
[Re: adam]
#499405
09/13/04 05:40 PM
thanks for the help guys. Randys? where are they located? could you give me their number, or page, if they have one. how's the gas mileage with the new gears and 36s? can you cruise at about 75 to 80 mph in the highway? thanks again guys.
[Re: gentouteg]
#499406
09/13/04 06:04 PM
[Re: gentouteg]
#499407
09/13/04 07:34 PM
how's the gas mileage with the new gears and 36s? can you cruise at about 75 to 80 mph in the highway? thanks again guys. I get about 15 mpg with that combo. I can cruise at 80 but usually keep it below that. The truck will accelerate in 5th again, too.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6173 MB (Peak: 0.6914 MB) Data Comp: Off Server Time: 2026-06-07 05:51:02 UTCValid HTML 5 and Valid CSS
