can i get new gears? #499401 09/09/04 03:32 AM
G
gentouteg Offline OP
i've been searching around the net, but can't find if anyone makes new differential gears for my truck. i have a 1995 toyota t100, 4wd, with the 3.4l. i have a four inch suspension lift on it with 33 inch bfg at. i noticed a bit of power lost after i put on the 33's. and now i want to put on a body lift and some 36's. so i was wanting to regear the truck. but couldn't find anything on it. does the t100 have a different axle than all the other toyotas? because i can seem to find gears for everything else but the t100. any help would be greatly appreciated.
Re: can i get new gears? [Re: gentouteg] #499402 09/09/04 05:32 AM
Fishen'man Offline
Welcome to the board<img src="/forums/images/graemlins/cheers.gif" alt="" />
Our T100's have a 8 1/4" gear set. Same as the tundra, sequoia and the non-trd tacoma.
Good luck <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: can i get new gears? [Re: gentouteg] #499403 09/09/04 07:03 AM
adam Offline
Call Randy's, they'll get ya all hooked up. I run 4.88s & 36s and find the gearing close to stock. Much bigger and 5.29s might be in order.
Did I hear somewhere that there's going to be a Dana 5.29?
~Adam
Re: can i get new gears? [Re: adam] #499404 09/09/04 06:11 PM
ErikB Offline
Toyota Moderator
The rear gears in a T100 are the same as a Tundra. The front gears are the same as '86-95 Toyota trucks/4runners.
http://home.4x4wire.com/erik/diffs
Re: can i get new gears? [Re: adam] #499405 09/13/04 05:40 PM
G
thanks for the help guys. Randys? where are they located? could you give me their number, or page, if they have one. how's the gas mileage with the new gears and 36s? can you cruise at about 75 to 80 mph in the highway? thanks again guys.
Re: can i get new gears? [Re: gentouteg] #499406 09/13/04 06:04 PM
urso8up Offline
1998 T100 4x4 3 body lift 4 procomp suspension 15x10 steel wheels and 35x12.50x15 Baja Claws
http://www.cardomain.com/id/urso8up
Re: can i get new gears? [Re: gentouteg] #499407 09/13/04 07:34 PM
adam Offline
I get about 15 mpg with that combo. I can cruise at 80 but usually keep it below that. The truck will accelerate in 5th again, too.
~Adam
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6199 MB (Peak: 0.6941 MB) Data Comp: Off Server Time: 2026-06-07 03:19:49 UTC
