power window problems #499618 09/09/04 04:48 PM
salb3039 Offline OP
Ok I've had some big problems out of my driver side window. I'm assuming the part know as the regulator (round spool with wire) is the culprit. Well, I know it is. All the wire had come off the spool and now the window will not open or close. To keep it up temporarily, I had to put a screw under the window inside the door. Really ghetto, but better than getting rained on. Ok, so here's my question. Is that part called the regulator? I've looked and the cheapest one I can find is almost $100. Does anybody have anything like that? Thanks for the help guys.
Re: power window problems [Re: salb3039] #499619 09/09/04 06:18 PM
$100 for a window regulator is pretty standard. I had both of them replaced on my Vx and the dealer had to pay $88 for each one.
Re: power window problems [Re: salb3039] #499620 09/09/04 08:55 PM
I replaced both rear in a 93 Trooper ~$77 each from St. Charles. I wouldn't take any short cuts here though, just get the OEM part from St Charles. My $.02
Good Luck
Re: power window problems #499621 09/10/04 01:17 AM
salb3039 Offline OP
Ok, is anyone close to me that knows how to do this? Cuz I have no clue how to do it.
Re: power window problems [Re: salb3039] #499622 09/10/04 04:58 AM
Scott F. Offline
dang, I've done it about 10-15 times <img src="/forums/images/graemlins/smile.gif" alt="" />
I tried to save some money and make a new cable and rewind the spool, didn't last too long.
Go for the factory new unit. If you were closer I'd get it done in 10min.
By the way its not hard, you just have to swap the motor from the old regulator to the new one and your good to go.
Good Luck
Scott F.
1995.5 Rodeo V6 Auto
Not enough money to put much here! I am taking donations <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5989 MB (Peak: 0.6610 MB) Data Comp: Off Server Time: 2026-11-17 11:02:56 UTC
