Page 1 of 3 1 2 3
GEN II sway bar removal for wheeling? #499824 09/09/04 10:41 PM
TeaQue Offline OP
My buddy has a tacoma (hes actually on these forums...)
anyways, he took off his sway bar and gained quite a bit of articulation (granted this would suck for normal highway driving)
could we/do we do this to our Gen II's? don't we also have a rear sway bar also? (i'm too lazy to leave my dorm and check right now smile )
also....one more question...would the lug pattern on a 98 Tacoma happen to be the same as my gen II?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499825 09/10/04 04:31 AM
TeaQue Offline OP
ok seriously.....NO ONE HAS TRIED THIS????
isn't it a common trick to take of the sway bars to gain articulation on other vehivles? <img src="/forums/images/graemlins/confused.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499826 09/10/04 04:57 AM
bretwalda Offline
I've done it to both of my Gen2's. Easy enough - should be able to get off by just removing the shocks. Removing the lateral rod and a spring will definitely make it even easier.
concreteprinter.com
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499827 09/10/04 03:08 PM
BobShaw Offline
It's not a trick, it is necessary for off road. Yes it makes the vehicle more unstable on the highway. Most of us use rims with a smaller rear backspacing and move the tires outward 2-4 inches per side. This gives you back some of the stability.
Bob Shaw
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499828 09/10/04 03:27 PM
Angelo Offline
Yes, it would.
Also, its not that hard to take the sway bars off. I currently have both my sway bars off, and yes, it gets tippy, but you just get used to it and you have to take it easy. I know, I know, I should put them back on, but havent gotten the chance to take the skids off and bolt it back on there. Just doing some testing <img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/drunk.gif" alt="" />
later,
Angelo
Re: GEN II sway bar removal for wheeling? [Re: bretwalda] #499829 09/10/04 07:51 PM
TeaQue Offline OP
you had to take your shocks off just to remove the sway bars? <img src="/forums/images/graemlins/confused.gif" alt="" />
did it seem to help much?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: GEN II sway bar removal for wheeling? [Re: Angelo] #499830 09/10/04 07:54 PM
TeaQue Offline OP
Yes, it would.
later,
Angelo
how bad does it really drive? is it a subtle difference?
for instance, i was told my ride would be horrible after cranking my T-bars but i thought the difference was negligible <img src="/forums/images/graemlins/confused.gif" alt="" />
will taking these off affect anything else on the truck? make anything wear prematurely?
thanks guys
<img src="/forums/images/graemlins/smile.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: GEN II sway bar removal for wheeling? [Re: BobShaw] #499831 09/10/04 11:25 PM
TeaQue Offline OP
Bob Shaw
if its necessary, and more people do it, then how come the replies are so lacking? <img src="/forums/images/graemlins/frown.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: GEN II sway bar removal for wheeling? [Re: TeaQue] #499832 09/10/04 11:52 PM
Big Blue Offline
You are lacking in replies as there are huge safety implications involved with removing them. I don't know you, or how you drive. What might be "safe" for you, may not be safe for the next ten people.
ANYTHING that compromises your handling on the road/hiways needs be thought about long and hard. How many people do you put at risk when you do this or that needs to be taken into consideration.
The gains are minor at best. Are you willing to remove them at each trailhead, and then re-install them before you head home after wheeling?
The removal of the rear anti-sway bar on some of our rigs allows for the trailing arms to fatigue much quicker, causing other possibly very ugly problems that could damage/destroy your truck and kill people. There are fixes/mods for those rigs, but until you do those mod's you should not remove your rear anti-sway bar.
IF you are talking about a "pure" trail rig that does not spend any time on roads/hi-ways, then sure pull them. BUT they are there to increase the safety of a vehicle that is already thought of by some to be tippy, and just plain un-safe, with a very high center of gravity. If you are involved in an accident, and while investagating the accident, it is found that the anti-sway bars were removed by the owner, you could be found at fault, even if the anti-sway bars had nothing to do with the accident.
NO-ONE should tell you that they are just fine without the anti-swaybars on them, as they don't drive where/what/when you do, and they don't know/drive your rig, under the conditions that you do.
OK, now you have a response.
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: GEN II sway bar removal for wheeling? [Re: Big Blue] #499833 09/11/04 12:50 AM
TeaQue Offline OP
Kary
thank you. <img src="/forums/images/graemlins/shocked.gif" alt="" />
thats what I was wondering, my friend with the tacoma took his off for awhile and he said he could articulate quite a bit better. if the gains are minimal and outweighed by the negatives then this is one mod i will stay away from <img src="/forums/images/graemlins/wink.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.023s Queries: 16 (0.017s) Memory: 0.6475 MB (Peak: 0.7742 MB) Data Comp: Off Server Time: 2026-11-17 11:02:29 UTC
