code 12 (knock sensor) ?
#44340
12/05/02 02:57 AM
Broke wire to knock sensor. Spliced , no luck. Searched & found a couple of threads. One said the wire to EFI comp. is a special ground wire. The dealer knows nothing about this wire. Does anyone have part # or suggestions? It also set a soft code 3. Don't know if this is related. I'll work on it tomorrow. It's kind of icy out tonight <img border="0" alt="[Yawn]" title="" src="graemlins/yawn.gif" />
85 4runner, 22re,cam, headers,2.25free flow exhaust,3"susp lift, 33's,custom bumpers,& stuff
Re: code 12 (knock sensor) ?
#44341
12/05/02 04:32 AM
Tell your parts man it should be part # 82219-XXXXX.I don't remember the exact # cause I left Toyota almost 4 years ago.I am with Lexus now but the first five of the part #'s are the same.If you really can't find it e-mail me you Vin and I could get it for you.
#44342
12/05/02 06:49 AM
What do you have, to be able to read error codes? Can you use a palm pilot or pocket PC's?
Just curious.
Thanks <small>[ December 05, 2002, 05:33 AM: Message edited by: ringo234 ]</small>
#44343
12/05/02 07:20 PM
You may be able to splice that connection, but if it "broke", it could be too damaged to splice (ie broke in more than one spot). I don't think this is a splice repair you'd do with a typical butt connector, you'd need to solder & shrink tube it, and be careful not to get it too hot as it could foul the sensor.
I ran mine for a looonnng time with a bad k code, and didn't suffer severe bad affects.
ringo, you can retrieve codes with a small jumper wire, and counting blinks on the "check engine" idiot light, a search will tell you the exact details.
Toy4x 90 ExCab SR5 V6 Auto In need 99 Taco samesame(ish)
#44344
12/05/02 10:30 PM
Do you think I could just run new wire from sensor to comp? Any one done this? I'm going to try to splice again with solder joint. Sounds good to me. Brrrr its cold out there in that shed. Will let you know what happens. The coil wire had come loose while I was fooling around with chk connector & had set the code 3. <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
