Gen 1 4 cyl conversion 5 speed to auto? #500019 09/10/04 09:01 AM
carnuck Offline OP
The more I look at this little rig, the more I like it (better than my wife's '01 Legacy anyways!) She can't drive a stick anymore due to injury (she gets sciatic nerve and knee joint pains after 5 miles and they lasted for a month so far!)
Probably too late anyways, since I am putting a new flywheel and clutch as well as starter in this one. (and a GM 1 wire alternator) I found a 2wd Mitsu pickup with auto I can probaly convert (but that would depend what the input is on the '87 Montero Tcase?)
Did Mitsubishi ever use an Aisan Warner automatic with the 4 cyl?
Build your truck the head men say, but it must be built in such a way...
Re: Gen 1 4 cyl conversion 5 speed to auto? [Re: carnuck] #500020 09/10/04 03:20 PM
BobShaw Offline
I don't think you will be happy with the older 5 speed tranny with aluminum case. They have shaft bearing problems. If you do go with one, have it rebuilt and upgraded.
Bob Shaw
Re: Gen 1 4 cyl conversion 5 speed to auto? [Re: carnuck] #500021 09/10/04 03:42 PM
don Offline
Other headaches...
The A/T is longer:
- the mounts are different
- the x-maember is different
- the tcase is further back
- the front drive shaft is longer
- the rear drive shaft is shorter
The carb also needs to be swapped out for the A/T version, and the linkage will be needed.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Gen 1 4 cyl conversion 5 speed to auto? [Re: don] #500022 09/10/04 06:23 PM
carnuck Offline OP
Which trans did they use? 904 or something else?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6016 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-05-29 18:49:17 UTC
