Front Wheel Bearing #500041 09/10/04 02:53 PM
W
Woodsie Offline OP
Anybody had to replace a frt wheel bearing on an '02 Runner?
Are they pressed out and in?
How hard to DIY?
Re: Front Wheel Bearing [Re: Woodsie] #500042 09/10/04 07:23 PM
FWIW... I had to have one replaced on my 96. Bearing are pressed, so I had it done.
Re: Front Wheel Bearing [Re: Woodsie] #500043 09/11/04 08:12 AM
Jeff the marmot Offline
They are pressed in and out. Based on experiences from people who have installed the manual hub kit, you are 99% certain to destroy the bearings when they are pressed out. So plan on buying new replacement bearings before you press them out. You need a shop press at a minimum if you want to DIY. There's also a special tool with a few pins that may be required to torque a ring to 200 ft-lbs. I actually didn't see that part of it so I don't know what I'm talking about there.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Front Wheel Bearing [Re: Woodsie] #500044 09/12/04 01:44 AM
kewlynx Offline
It's not hard to do yourself IF you have the right tools and all your parts before you start.
Go to the Toyota maintenance section on this site and read up on the front end maintenance article to see what all is entailed.
**ubi apis- ibi salus**
Re: Front Wheel Bearing [Re: kewlynx] #500045 09/13/04 12:49 PM
W
Woodsie Offline OP
That bearing isn't a cone and race bearing, its a ~2" wide sealed bearing. Cost like $70. Guess I need to find a manual for a 2002. That's not EZ either. Anybody else looked for one? Aftermarket? Anybody have one?
Re: Front Wheel Bearing [Re: Woodsie] #500046 09/13/04 01:11 PM
kewlynx Offline
FWIW, most of us have the pre-Taco rigs, so you're on your own with a fancy schmancy new rig in the Runner zone. No knocks; that's just the way 'tis. Here's a link for an FSM. Yes, they're not cheap, but if you're going to keep your rig a long while, GET ONE. Had my 86 for 2 years before I got one for Christmas; still drivin the ol' gal. Good luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
http://www.4x4wire.com/forums/showf...87633&fpart=1&PHPSESSID=
Re: Front Wheel Bearing [Re: kewlynx] #500047 09/13/04 03:05 PM
Actually, your question is on the correct forum, Woodsie. Most people on this 'Toyota 4Runner and SUV' forum have '96 or newer rigs.
Jeff
PHP: 7.4.33 Page Time: 4.540s Queries: 15 (0.004s) Memory: 0.6149 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-06-15 01:43:16 UTC
