need brake help
#500248
09/11/04 01:18 AM
noticed a sqeaking noise on pass side wheel and noticed the metal clip????? on the brake pad isnt there.. is this bad? what does the clip do? there is alot of brake left . thanks
Re: need brake help
[Re: catman25]
#500249
09/11/04 02:08 PM
Excessive brake dust, or even just trail dust used to make my front brakes squeek.
As for the metal clip on the brake pad, it is there to warn you when the pads need to be replaced. It will rub against the rotor, thus it wont ruin the rotor like when the pad runs out.
Why go around? When You can go over!
Re: need brake help
[Re: KIAFREEKROB]
#500250
09/11/04 03:48 PM
so i donbt need it or ???are my pads worn down or did it just come loose..there must be a pinky full of pad left on both sides.
Re: need brake help
[Re: catman25]
#500251
09/12/04 03:01 AM
If the pads are hard and they can glaze over squeek. Not too much you can do about it unless you want to try to sand the pads down to get the glaze off.
I just replace my front pads because of this (they were worn to about 3/4). I'm experimenting with a soft pad from ARB. quicker stopping time, but don't know how long they'll last.
The clip probably broke off? As far as I know, all pads today use clips. Some older pads were designed to squeal when fully worn down requiring no external clip. But I haven't seen these in a long while.
Later... Joe R. 97 Kia Sportage - Eibach 2 lift , 30" A/T's, Warn manual hubs Hi-Lift, GPS.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6010 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-10 06:10:05 UTCValid HTML 5 and Valid CSS
