weber carb bolt pattern #501135 09/13/04 05:54 AM
Does anyone have know the bolt pattern for a weber carb? Specifically a 32/36 model.
Re: weber carb bolt pattern #501136 09/13/04 07:27 AM
carnuck Offline
It's different enough that you need a Redline adapter to bolt it on! (have one on my '87 first gen 4 cyl that I hope to finish fixing soon!)
Build your truck the head men say, but it must be built in such a way...
Re: weber carb bolt pattern [Re: carnuck] #501137 09/13/04 02:32 PM
I need to know the bolt pattern because I am planning on converting to fuel injection and I have a throttle body in mind, but want to see if the bolt pattern is the same. Otherwise I'll have to get a custom adapter made. I'm hoping the Redline will fit or close enough.
Re: weber carb bolt pattern #501138 09/14/04 06:20 PM
anyone?
Re: weber carb bolt pattern #501139 09/14/04 08:37 PM
carnuck Offline
try here
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5957 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-05-29 17:12:08 UTC
