Re: Do all 16 w/ 5.5 spacing rims fit my rodeo? [Re: Rodeo Guy] #501425 09/21/04 11:40 PM
4
4Play Offline OP
Thanks for all the speedy input! I bought the rims and now Im in the process of mounting the tires to the rims.
Hopefully I won't have to trim too much <img src="/forums/images/graemlins/frown.gif" alt="" /> Im not ready for her to look like an all out off-roader yet <img src="/forums/images/graemlins/shiner.gif" alt="" /> Im still makin payments!!
Anything I should be aware of when takin the sawzal to her?
Re: Do all 16 w/ 5.5 spacing rims fit my rodeo? [Re: Smiley] #501426 06/07/05 01:40 AM
rheteric Offline
There are two different sized hub openings for 6-bolt / 5.5ö wheelsà
The ones on our Isuzus (as well as Toyotas, Mitsubishis, Nissans, etc.) have the larger of the two hub opening sizes. --- Whereas, those on many (if not all) Chevrolets, GMCs etc. have the smaller hub openings.
Just because they are 6 on 5.5 wheelsà that fact alone DOES NOT mean that theyÆll fit!
Bearing this statement in mind, would most/all aftermarket wheel makers make the 6 on 5.5 wheels with the larger hub opening to ensure a more universal fit? i.e. all domestics and imports with 6 on 5.5.
FYI: I am looking at getting some Eagle 187s (1879-7866); anyone speculate how these compare fit-wise to a stock 16x8 steely with 265/70/16s (31s)?
www.burnlounge.com/mp3me
'00 Rodeo LS 4x4; "K&N" cone filter; S/S Manik Front, Rear, & Nerf; 'Modest' sound system; 1.5" R'ooper lift, 265/70/16 Dunlop RVxt, Skyjacker Hydros, OEM LSD (sans G80 code)
Re: Do all 16 w/ 5.5 spacing rims fit my rodeo? [Re: rheteric] #501427 06/07/05 07:35 AM
Smiley Offline
I canÆt say about those Eagle 187s that youÆre looking at, butà
On my last trip to Sears, I saw a few sets of 16 and 17 inch / 6 on 5.5 wheels that caught my eye (not that I could actually afford any of them <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> ) - but for what itÆs worth, NOT ONE of them had the larger hub opening. <img src="/forums/images/graemlins/frown.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Do all 16 w/ 5.5 spacing rims fit my rodeo? [Re: Rodeo Guy] #501428 06/07/05 09:54 PM
F
Frisky Offline
Toyota rims fit. The only 6 lug pattern I've ever heard of is 6 on 5.5, so the only thing you have to worry about is the hub size, but yes Toyota rims do fit on isuzu.
Actually the Dodge dakota pickups use a different 6 lug pattern. I think that is the only 6 lug pattern that the holes don't line up on. I have heard of people having problems with stock Chevy wheels fitting due to the hub cutout. My wheels came off of a suburban, but they were AR aftermarket steel wheels, so the opening was the larger.
Just my 2 sense <img src="/forums/images/graemlins/smile.gif" alt="" />
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: Do all 16 w/ 5.5 spacing rims fit my rodeo? [Re: Frisky] #501429 06/11/05 04:39 AM
Z
ZooMigo Offline
It was my experience with my 99 migo that Isuzu uses the smallest hub-centered rim with a 6x5.5 lug patten. It wasnt a problem putting most any rim on (except for the backspace issue), but I tried to put my stock rims onto my wife's toyota (also 6x5.5) and they would not fit over the centering ring.
Strangely, the 92 Amigo uses the same size ring as the toyota. 2nd gen rims ONLY fit 2nd gen migos/rodeos.
Not sure about troopers there.
Kevin
White '99 5Speed Softie. Some extra custom junk. - RIP
Stock Pink 92 2WD Amigo : Flamigo smile
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6165 MB (Peak: 0.6990 MB) Data Comp: Off Server Time: 2026-11-17 11:30:38 UTC
