Noisy engine power loss
#501467
09/14/04 12:38 AM
87 yj 4.2 w/ Howell FI and Hei ignition.The problem is when the engine is cold,Jeep runs awesome has power and pulls good even at 70 mph on highway.When the engine warms up it makes noise ay about 2500 rpm and losses power
Re: Noisy engine power loss
[Re: DRCYCLOPS]
#501468
09/14/04 12:41 AM
tune it up. your electronics are probably weak. maybe even a bad distributor. if it was internal it would be noisy from startup.
[Re: valleycat]
#501469
09/14/04 07:12 AM
does it ping or detonate? if either are occeruiong you can first try 91 octane if it still is doing it you'll have to retard the timing a bit. if you let it ping/detonate i garntee you'll blow a hole through a piston. if it does it immidiatly get off the throttle.
#501470
09/15/04 11:56 PM
Yeah set it at 7 degrees @ 1600 RPM,VROOM no noise,LOTSA POWER Thanks guys some times you got to go back to basics so you dont get caught <img src="/forums/images/graemlins/sleeping.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5944 MB (Peak: 0.6518 MB) Data Comp: Off Server Time: 2026-06-17 11:58:45 UTCValid HTML 5 and Valid CSS
