fj-60 parts swaps #501524 09/14/04 01:41 AM
kjishikawa Offline OP
posted about a week ago on finding an '83 LC. Went back to check it out today. I was thinking that since it was bigger than my 4runner I would be able to upgrade some parts but it looks to be all 4 cylinder running gear! I was thinking of doing the brake upgrade, but the calipers are the same as the 4 cylinder ones, so I guess I'll wait to find some v-6 ones. The master cylinder was 7/8" but had another little cylinder running perpendicular under it. Also, the booster didn't seem any bigger in diameter than my '85's but looked alot thicker. Are these just as good as the 1" v-6's? The third members were also the 4 cylinder variety, anyone happen to know the gearing in these? I'll probably go back tommorrow for the knuckles, hopefully I can salvage those rotors, they were kind of rusty. Anything else I should be looking to pull off tommorrow?
Re: fj-60 parts swaps [Re: kjishikawa] #501525 09/14/04 11:56 PM
kyle-22r Offline
ah, no the thirds aren't 4 banger thirds! at least the rear, anyway. i think the rear uses something like an 8.7? ring gear
'91 4x4 shortbed
22R-E, W56, the dd!
Re: fj-60 parts swaps [Re: kyle-22r] #501526 09/15/04 09:58 AM
anthony1 Offline
The thirds on those are 8" high pinion. the front ones are reverse cut 8" thirds.
FJ60 in 83 came with inline 6 cylinder.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: fj-60 parts swaps [Re: anthony1] #501527 09/15/04 11:58 AM
I posted on the LC board and was told, "They are fine spline pinion, 3.7 diffs. They will not fit your mini." I'm looking for 4.56 or 4.88, but I know the high pinions are highly sought after. The diff housings looked exactly like the 4 cylinder housings though, with 3 fins and they didn't look high pinion. Are these something I want to grab?
Re: fj-60 parts swaps [Re: anthony1] #501528 09/15/04 06:46 PM
DirtyHarry Offline
Toyota Moderator
FJ-60 differentials are the same as those used in FJ-40s. They are not interchangable with mini truck differentials. The high pinion 8" third member came in the front of FJ-80 Land Cruisers, not FJ-60s.
Re: fj-60 parts swaps [Re: DirtyHarry] #501529 09/16/04 05:02 PM
4
4runner4ever Offline
LC 60 series use 9 1/2" front and rear. (in Europe anyway)
The LC 70 use a high pinion reverse cut 8" up front (4.3 / 4.56 or 4.88 OEM) and the 8" in the back.
The LC80 also use a high pinion reverse cut 8" up front (3.7)and the 9 1/2" in the back.
So yes, you can't swap the 60 series diffs.
Black '90 4R
SAS with LC80 coils and LC70 high pinion axle
LC80 rear axle, coils and locker
4.88 gears
2JZ-GE+turbo+intercooler
Re: fj-60 parts swaps [Re: 4runner4ever] #501530 09/17/04 04:07 AM
larsdennert Offline
In south america they use Dana axles...
Re: fj-60 parts swaps [Re: larsdennert] #501531 09/17/04 04:55 AM
kyle-22r Offline
dana axles? huh?
all i know of toyota using non toyota axles is in south africa, where they use a locally made rear end(to comply with laws stating that a certain % of a truck has to be made in the country)
'91 4x4 shortbed
22R-E, W56, the dd!
Re: fj-60 parts swaps [Re: kyle-22r] #501532 09/17/04 06:04 PM
DirtyHarry Offline
Toyota Moderator
I can verify that Dana axles are used in Venezuela. The FJ70s down there had offset small tube semi float 6 lug Dana 60 rear axles.
Re: fj-60 parts swaps [Re: DirtyHarry] #501533 09/17/04 07:13 PM
4
And I can verify that in Europe they use Toyota axles on the 70 series. I swap those parts all the time with pickups.
And I have the 70 series front axle (high pinion) with coils and 3 link suspension in the front of my 4R. <img src="/forums/images/graemlins/smile.gif" alt="" />
Not that odd if you think about it. My first pickup was a VW Taro which was a Toy Hilux with factory VW emblems. All parts were shipped to Germany where some VW guys bolted everything together. This was done due to some import tax advantage, so looks to me like this can happen all the time.
On a trip to Portugal I found that the Toy Hilux was sold there without bed, rear lights etc. You were supposed to build your own bed! <img src="/forums/images/graemlins/shocked.gif" alt="" />
I saw tons of those with the same nose as mine, but with a wooden shed were the bed normaly is.
Looks like they were hauling there garage around town. <img src="/forums/images/graemlins/lol.gif" alt="" />
Black '90 4R
4.88 gears
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6454 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-06-07 03:53:49 UTC
