ARB Bullbar and 3" body lift #501994 09/14/04 11:33 PM
Sturdy Offline OP
Has anyone installed an ARB Bullbar with a 3" body lift?
I am curious if it looks or fits okay? Has anybody modified a bullbar to fit a 3" body lift? Any feedback and/or pics would be helpful.
Thanks in advance.
Mike
Mike
04 Tundra
01 Discovery
93 Trooper RS- Lifted, Locked- SOLD
93 Trooper RS- Teras, Lifted, Locked- ROLLED&SOLD
87 Trooper-Lift-SOLD
90 Trooper-Teras and lifts-SOLD
96 Trooper-Graveyard
Re: ARB Bullbar and 3" body lift [Re: Sturdy] #501995 09/15/04 12:00 AM
TXCO RIG Offline
There will be alot of people with alot of info if you can amke it out to Barnwell mtn this weekend,check the trail section of the board.Hope you can make it out.
99 Trooper 3" Indy lift,Rancho 9000's,RIP
91 Trooper 2.4l, Indy 3in,32x11.5,5 BFG's on black Rock Crawlers,Confer rack ,Pro Comp lights,Warn hubs,XM radio
97 Zj
Re: ARB Bullbar and 3" body lift [Re: TXCO RIG] #501996 09/15/04 12:39 AM
W
Wareagle Offline
Will you post back w/ any learnings? I've been wonmdering same thing. Supposedly, there is a local guy w/ 4runner that has made some adapters. I'm told they are platres with 6 - 8 half moon shaped holes. If I ever see the work, I'll try to post some pics.
Re: ARB Bullbar and 3" body lift [Re: Wareagle] #501997 09/15/04 01:25 AM
Starchild Offline
I beleive Darlington Off-road caries or makes a bumper bracket for 3" body lifts. Since the ARB uses stock mounting points, if I'm not mistaken, It should work. I'm sure Mr. Darlington could provide more info than I.
HIH.
Andre
"SERENITY NOW!"
Re: ARB Bullbar and 3" body lift [Re: Starchild] #501998 09/15/04 01:55 PM
Bigpoppax2 Offline
If we're talking winch bumpers you need to make certian that these brackets will be strong enough and not bend or allow your bumper to bend down.
I know I recall someone posting about their bumper being pulled down when winching.
Re: ARB Bullbar and 3" body lift [Re: Bigpoppax2] #501999 09/15/04 03:14 PM
sweater Offline
At least on a Rodeo, there are only two bolts holding the the front bumper on, and those are not enough (IMHO) to support serious winching. Most people drill out another hole and add another grade 8 bolt to help stabilize the front.
Since the bumer ties into the frame, I don't think you'd have any problems with a winch bumper bolting directly to the frame. Add some brackets to raise it to the same level as the body, and you're increasing the moment arm when winching. This'll put much more stress on those bolts and mounting points. It's the same when you try to free a bolt with an 8" handled ratchet, then slap an 18" breaker bar on there and it spins right off.
Re: ARB Bullbar and 3" body lift [Re: TXCO RIG] #502000 09/15/04 04:39 PM
Sturdy Offline OP
Unfortunately I can't make it out to the trails this weekend due to family obligations. If you have any information or could maybe ask some folks out at Barnwell that may have some answers we would sure appreciate th knowledge.
Thanks
Mike
Mike
04 Tundra
01 Discovery
Re: ARB Bullbar and 3" body lift [Re: Starchild] #502001 09/15/04 06:12 PM
if you are talking about the brackets you get with the body lift kit, then I would NOT suggest using those. I wouldn't trust them for someone standing on the bumper much less putting any kind of serious weight on them. There is a warning that comes with the kit that states the brackets are to maintain cosmetic function only.
Re: ARB Bullbar and 3" body lift #502002 09/16/04 01:32 AM
Sturdy Offline OP
Not even a consideration, those brackets can barely support their own weight.
Mike
Mike
04 Tundra
01 Discovery
Re: ARB Bullbar and 3" body lift [Re: Sturdy] #502003 09/29/04 02:08 AM
Sturdy Offline OP
Does anybody have any direct knowledge/experience with this?
Mike
04 Tundra
01 Discovery
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6363 MB (Peak: 0.7601 MB) Data Comp: Off Server Time: 2026-07-13 14:30:00 UTC
