a inch of antifreeze on the floor of my trooper! #502512 09/16/04 05:58 PM
Dank4x Offline OP
hey guys, u guys don't hear much from me but i have been around for a while, im more of a reader than a talker, but anyways the other day i opened the door to my trooper and smelt antifreeze i looked down and my carpets are soaked with it and i mean WET i had to tear all the carpet out. im thinking it has to do with the heater core, i re-routed the heater hose that comes from the fire wall easy fix, but the problem is that it's starting to get a little cold at nights here in colorado,so im going to need a working heater, any input would be greatful
90 trooper. 3inch BL. 3inch Suspension, 33in BFG muds sitting on 15x8 rockcrawlers, roof rack, calmini front double tube bumper with two kc's, hypertech power chip, spare tire hi-lift mount,flipped lid with K&N drop in filter more to come
Re: a inch of antifreeze on the floor of my trooper! [Re: Dank4x] #502513 09/16/04 06:06 PM
mlclark Offline
Isuzu Moderator
I am not sure what you are looking for here, but if you want a working heater, then you need to replace the core. Now, I know you know this, so....the hardest part will be finding a core. I know Modine lists one, but I don't know if it actually exists. The dealer and junk yard are your other options.
After that, go down to your parts store and ask to rent their metric set of double-jointed heater core midgets and tear into it. AFAIK, it is not a bad job, just cramped.
Good Luck,
Michael
Re: a inch of antifreeze on the floor of my trooper! [Re: mlclark] #502514 09/16/04 06:09 PM
Dank4x Offline OP
well i was thinkin it was the heater control valve, but either way im going to have to tear into the core.
Re: a inch of antifreeze on the floor of my trooper! [Re: Dank4x] #502515 09/16/04 08:35 PM
W
Wayne Offline
The return of the double-jointed midgets.
Besides the heater midgets (above), there's also double jointed:
ò EGR cleaning midgets
ò Starter Midgets
ò fuel pressure & timing checking while driving midgets
ò transmission filling midgets
And more. Good to see someone's keeping them busy. <img src="/forums/images/graemlins/smile.gif" alt="" />
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6061 MB (Peak: 0.6621 MB) Data Comp: Off Server Time: 2026-06-07 09:07:39 UTC
