q about 87 rear disk conv #503815 09/20/04 01:17 AM
i must have thrown these parts way on accident and didnt realize i neede them until now. i have the rear housing and axles...i think i need an outer flange to cap off the outer wheel bearings. was there a flange i needed to remove from the drums that goes on the end of the axle housing?
Re: q about 87 rear disk conv #503816 09/20/04 06:07 PM
rob_dup1 Offline
the flange that you want is usually still attached to the axle, right behind the bearing.
unless you pressed the bearing off ?
Re: q about 87 rear disk conv [Re: rob_dup1] #503817 09/20/04 08:38 PM
i pressed the drum off using the driveway... and tossed the whole thing.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.5877 MB (Peak: 0.6414 MB) Data Comp: Off Server Time: 2026-11-19 05:33:36 UTC
