what too look for in an 85. #504169 09/21/04 02:36 AM
Stomper Offline OP
Im going to look at an 85Runner this weekend. If this was a Tacoma I would know what too look for but its not. SO I come to you guys for advice. I saw the other thread but didnt see what im looking for.
What im looking at 85 with recently rebuilt 22re with a bigger cam new exhaust system. 4.5" lift by springs 3"B/L 5:29's full detroit in rear true trac in front sitting on 35's. Birfields rebuilt but not sure how long ago. New paint clean inside and out.
What kind of things should I look for. I/E rust areas and such.
Thanks guys
1985 4runner
Re: what too look for in an 85. [Re: Stomper] #504170 09/21/04 03:04 AM
Pappy Offline
4.5" spring lift? Make sure it has cross-over steering, or be ready to install if you plan on wheeling. The draglink can't handle the angle and the bump steer will scare the schit out or you.
Rust will be mostly on rear quarter panels, and under doors. Check frame for rot too.
Re: what too look for in an 85. [Re: Pappy] #504171 09/21/04 03:16 AM
Stomper Offline OP
Thanks Im not sure if the crossover has been done yet if not I can handle that. anyone else.
1985 4runner
Re: what too look for in an 85. [Re: Stomper] #504172 09/21/04 03:36 AM
Stomper, check the frame for cracks around where the steering box is and where the frame connects to the front crossmember. When I bought my 85 4runner it was cracked. Didn't find it for a while. Had to cut the front crossmember off and replace it and I also had to plate the frame to reinforce it.
Re: what too look for in an 85. [Re: Stomper] #504173 09/21/04 08:43 PM
fourwd1 Offline
#1 thing to look for is [color:"red"]RUST[/color].
Especially the frame, which rusts from the inside out, so by the time it's obvious it's really bad. Check both sides of drvr and pass side rails, esp where it angles upward or downward and where fuel tank sits against it. Use a hammer or someting to tap along looking for bad spots. Also check cab mounts.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: what too look for in an 85. [Re: fourwd1] #504174 09/22/04 02:49 AM
Stomper Offline OP
Thanks to everyone for the tips. Keep them comming.
Fourwd1 thats a good Idea about the hammer I dont think I would have thought of that.
1985 4runner
Re: what too look for in an 85. [Re: Stomper] #504175 09/26/04 03:08 PM
Stomper Offline OP
Well I ended up buying the $Runner. The frame looked good so I guess ill be looking into Hysteer now. Also The rear was lifted with csat Iron Blocks so those will be going too.
1985 4runner
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6147 MB (Peak: 0.6929 MB) Data Comp: Off Server Time: 2026-11-16 01:17:18 UTC
