Couple problems, need help fast #504494 09/21/04 10:08 PM
Sid's Toy Offline OP
1992 3.0 5 speed, not dailey driver but still drives alot.
A couple of months ago, I had a short in a wire behind the dash and blew the efi fuse. Once I fixed that, the speed senosr blew so I have no speedometer which was fine because the tach still worked properly.
Today, I drove it to school and everyting was normal. After it sat for 9hrs or so, it started fine and drove 1/4 mile or so, then noticed when ever I let off the gas, it sounded like something was dragging on the ground (metal on concrete). I asume it is the cat converter gone bad. There is 75 to 90% loss of power so going up any hill was unbearably slow.
Next my tach goes out on the same drive home while going slow for 10 miles or so till I made it home. I tried to roll up the power windows and nothing. So I tried to replace the gauges fuse (the gauges and power windows are on the same fuse I beleive) and blew it as soon as I tried to roll up the window.
The only thing different in the last couple of days driving the runner was the speedometer was bouncing around between 0 and 60, flickering rapidly sometimes. Before it did nothing. So any ideas.
1. It the cat the solution for solving the power problems
2. Would the flickering speedometer blow the gauges fuse, should I disconnect this untill I replace it (which may be in a couple of months)
3. What can I do to at least roll my power windows up for the time being
Cheers
Sid Crocker
Oh, what a average price to replace the cat and O2 sensor.
92 4Runner SR5 3.0 standard tranny
4.88 gears, rear elocked, OME coils, SAW Tbars, allpro rock sliders and rear bumper, custom made front, downey v6 headers ...
Re: Couple problems, need help fast [Re: Sid's Toy] #504495 09/22/04 03:11 AM
Kaptain Offline
"1. It the cat the solution for solving the power problems"
The Cat is a good place to start since the power loss happened all at once. Atleast take it off and have a look
inside.
"2. Would the flickering speedometer blow the gauges fuse,
in a couple of months)"
Your speed sensor should be okay, have a look at the
connector to the speed sensor. I had the same problem
and one of the three pins happened to break off causing
a unstable connection.
"3. What can I do to at least roll my power windows up for
the time being"
Dunno what to say about your power windows other then check to make sure you dont have a short, and make sure your
putting correct fuse back in. Gotta love manual windows!
I actually just bought a new cat converter <a href="www.autopartswarehouse.com" target="_blank">here.</a> It was $90.50
shipped, and it's a direct bolt on. I have the 4cyl, so
I don't know if it's the same or not.
At 1sttoyotaparts.com the 02 sensor is around 90 bucks
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5895 MB (Peak: 0.6386 MB) Data Comp: Off Server Time: 2026-07-16 22:47:30 UTC
