7MGE troubles #504993 09/23/04 02:45 AM
Paul Elbisser Offline OP
I got a miss in #4 cyl. It runs fine till I get it warm, and shut it down. When I start it back up it has a miss.
Swaped plugs between cyl, no change
put in my spare plug wire, no change
Any idea what to look at next?
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: 7MGE troubles [Re: Paul Elbisser] #504994 09/23/04 02:50 AM
SHAD Offline
How's the cap? possibly bad distributor? so I am assuming no spark on that cylinder at all after it gets warm?
Have you done a compression test on the cylinder in question?
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: 7MGE troubles [Re: SHAD] #504995 09/23/04 04:51 AM
BoostedInline6 Offline
Does the idle eventually smooth out?
Check the fuel pressure up vacuum switching valve (FPU VSV) mounted below the intake manifold. It has both an electrical connection and two vacuum connections. If any of these connections failed, you'll have a rough idle on a warm start up.
2000 4Runner | 5-speed | E-locker | Tundra/OME 2" lift | Stubbs Sliders | Deckplate/TrueFlow |
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.014s) Memory: 0.5930 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-11-19 05:33:35 UTC
