Help! need injector wiring info! #505171 09/23/04 06:23 AM
solarcrew Offline OP
<img src="/forums/images/graemlins/drunk.gif" alt="" />I had to be drunk to do something this dumb.I had the head off to replace rocker arms and install a new timing kit.I decided to go through the wiring harness and check for bad connections.Well,I ended up pulling the wires out of one of the injector plugs.I also forgot to mark where each one goes.I know 2 of them have a blue & a white wire.The other 2 have a white/red and a yellow wire.Can anyone tell me which connector goes to each injector.I tried to decipher my haynes book.It seems to show the blue/white connectors go to #2 & #4 injectors.The white/red-yellow connectors go to #1 & #3 injectors.Also,if anyone knows the polarity of each wire.Let me know.Thanks in advance for your help! <img src="/forums/images/graemlins/cheers.gif" alt="" />
87'4runner-22re,5spd
Re: Help! need injector wiring info! [Re: solarcrew] #505172 09/23/04 07:21 AM
Esquire812 Offline
Yella wires paired with the White/red go to #1 and #3 and Blues go to #2 & #4 as you said.
Looking at the top of then connector where the wires enter...colored wires are left, whites on the right...for all four. For reconnecting to the injectors start at #4 and work back up to #1. The wiring tails only stretch as far as the injector they are intended to mate with...unless you work real hard at forcing #1 onto #3 etc.
Booze and Wiring....bad juju. <img src="/forums/images/graemlins/shame.gif" alt="" />
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Help! need injector wiring info! [Re: solarcrew] #505173 09/23/04 07:26 AM
kewlynx Offline
Hah--you're lucky some of us toggle threads--- in case you need it, and hopefully you won't
22RE injector wires
10-4 with Darin, beer stays on ice until yer done. Gets nice and cold, and you can get the work you wanted out of your buddies before they get lead butts!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: Help! need injector wiring info! [Re: kewlynx] #505174 09/23/04 03:20 PM
<img src="/forums/images/graemlins/kewl.gif" alt="" />Thanks for the info folks.I got everything back together.Darin,I also went to the secret bible you sent me to get some info.Now can't seem to get fuel to injectors.Is it possible to air lock the fuel rail after having it disconnected.Should I try to bleed it.Thnx again! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Help! need injector wiring info! [Re: solarcrew] #505175 09/23/04 05:53 PM
Esquire812 Offline
The fuel rail is self bleeding. Stick a jumper wire into the diagnostic box between Fp and B+, turn ignition to ON and you should be able to hear the fuel rushing through the rail with little if any trouble. It'll make some gurgling and perculating noises as the air is pushed out...once you get a steady flow (consistant sound) pull the jumper and fire that bad boy up. If your injectors arent firing...you missed a connection or ground while sipping the suds. LOL
*The "bible" has recently been made unavailable...did you download or print it out??
85' Sillyca 22R-Esq
Re: Help! need injector wiring info! [Re: Esquire812] #505176 09/23/04 09:15 PM
<img src="/forums/images/graemlins/ignore.gif" alt="" />I wasn't really drunk,just dumb! <img src="/forums/images/graemlins/lol.gif" alt="" /> You're right it is gone.Here's the one I clicked on my favorites,I think it's some of the same stuff.http://www.autoshop101.com/autoshop15.html.Thnx again,I'm headed out to connect those jumpers. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Help! need injector wiring info! [Re: solarcrew] #505177 09/24/04 12:10 AM
<img src="/forums/images/graemlins/confused.gif" alt="" />Darin,did you have any luck with the web site above? I've got one last question for you.OK,I got the truck running,the jumper you showed me let me know the fuel pump was ok.Apparently when I went to jump the connectors to set the timing,I blew the efi fuse.My question is,if the distributor is off 1 tooth either way,will it cause a high idle if off one way and a low idle if off the other way.I set the timing at 5 btdc but I can turn the idle screw all the way in and it still idles.I turn it out 1 full turn and it skyrockets up to 1800 rpm.Any clues on this.thnx,Doug <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Help! need injector wiring info! [Re: solarcrew] #505178 09/24/04 01:48 AM
Esquire812 Offline
If you are off by one tooth on the distributor, you can usually get it close to running correctly by spinning the distributor fully one direction or the other...essentially making you only 1/2 a tooth off. And yes, 1 off either direction will cause it to run like schidt or like a raped ape...dont ask which direction does what- my brain is pickled. But if you were able to set the timing to 5* BTDC and the distributor lockdown bolt was riding mid slot...then your distributor isnt off a tooth. Chain might be though. If you can crank the idle screw in fully closed and the engine still runs then you have air getting in somewheres. Look around again for any source of vaccum leak. Length of hose makes a good stethascope for searching for leaks around the intake. Is your Auxiallary air thingy all hooked up proper?? Ya know the valve thats directly under the throttle body. Double check to make sure the EGR coupler nut is tight. When my 4Runner ran with the idle screw shut I found that I hadnt tightened the coupler....oops. Once sealed problem was solved.
85' Sillyca 22R-Esq
Re: Help! need injector wiring info! [Re: Esquire812] #505179 09/24/04 01:53 AM
<img src="/forums/images/graemlins/kewl.gif" alt="" />Don't have the aav anymore.Switched to a 90's style intake.I'll check for air leaks.thanks again! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6300 MB (Peak: 0.7359 MB) Data Comp: Off Server Time: 2026-11-01 23:49:05 UTC
