91 Power steering leak #505708 09/24/04 06:47 AM
I have a 91 6 cylinder 4x4. It had a little PS leak, I cleaned everything a couple of different times, but could never tell exactly where it was leaking from. It is now leaking A LOT. Is this a classic problem on these trucks? Does the pump itself leak? It seems to be coming from at or near the bottom of the pump. There are no obviously loose fittings. The lines appear to be fine. Any suggestions as to where to start or do I just have to clean it and start pulling everything apart?
Re: 91 Power steering leak #505709 09/26/04 06:27 AM
rick92 Offline
Yes this is a common problem. I had a slow leak on my 92 4runner for years and I fixed it last summer. I used the PS Gasket Kit from Toyota P/N 04446-20090 for $35. Adds an hour or so to the job replacing the gaskets and rings but I wanted to try it myself. To date no leaks. If you don't want to rebuild yourself call the local auto stores. Lastly, if not already, only use ATF in the PS system. Good luck.
Re: 91 Power steering leak [Re: rick92] #505710 09/27/04 07:53 PM
E
Eck Offline
No big deal to rebuild it yourself. Don't forget to insert the vanes correctly with the radius side on the outside.
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: 91 Power steering leak [Re: Eck] #505711 09/29/04 06:14 AM
Thanks guys, do I yank the pump and just replace all the seals with those from the kit? I have a Chilton manual, but it is not much help. I'm a reasonably competetent mechanic....are all the replacements obvious?
What do you mean by the vanes? I assume you mean the blades on the pump?
Re: 91 Power steering leak #505712 10/02/04 06:30 AM
kewlynx Offline
Here ya go; THIS might help.
Also, just FYI. These pumps do NOT like cheapazz power steering fluid. Dextron II or III only.
**ubi apis- ibi salus**
Re: 91 Power steering leak [Re: kewlynx] #505713 10/02/04 07:36 AM
Thank you! And Thanks to Eck who sent me details as well! Now I should be able to stop the flood of PS fluid on my driveway.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6062 MB (Peak: 0.6752 MB) Data Comp: Off Server Time: 2026-11-18 03:21:21 UTC
