Turn Signal Relay? For a '90
#505750
09/24/04 11:02 AM
Tried searching but it doesn't seem to be working properly...
My question is, has anyone found a suitable replacement relay for the turn signals? Mine doesn't like the cooler weather and I've tried cleaning it. I had been using a Wagner 323 relay for the winter time but it's not working and I can't locate one of those either.
I appreciate all suggestions, thanks!
'00 Cherokee, Blue '09 4dr Wrangler What I miss...my '90 and '91 Montero's, but the Jeep's are cool.
Re: Turn Signal Relay? For a '90
[Re: whitebomber]
#505751
09/26/04 06:03 AM
is this the relay mounted on the driver side kick panel closest to the firewall or closest to the door jamb??? <img src="/forums/images/graemlins/confused.gif" alt="" />
#505752
10/03/04 02:17 PM
Actually along the firewall just next to the 4-way relay. I switched with the 4-way relay and I still have the same problem.
The left works fine but the right only works in warm weather. Seems to be a contact issue, so I'm hoping I can clean the contacts on the steering cloumn.
Any thoughts???
Thanks...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5894 MB (Peak: 0.6425 MB) Data Comp: Off Server Time: 2026-06-20 18:45:21 UTCValid HTML 5 and Valid CSS
