Power Brakes Question #507870 09/30/04 02:24 PM
Junkie Offline OP
Installing power brakes on my 86' CJ. Have a 6cyl. w/ a Weber Carb. Where can I pull vacume from? If you have a picture that's even better, unless it's pretty obviouse. There is no provision on the carb base as is on say a Ford 302. Any help would be greatly appreciated. Thanks in advance!
Re: Power Brakes Question [Re: Junkie] #507871 09/30/04 06:58 PM
i'm not sure about the manifold on your jeep... but if it doesn't already have a port thats been sealed.. i've seen people pull the manifold and drill and tap a new port for the booster.
Re: Power Brakes Question [Re: Junkie] #507872 09/30/04 11:06 PM
brightray Offline
On my Jeep I have a port on the carb adapter that came with my Weber carb. You must have a different manifold than I do. My jeep is an 86 also with the stock manifold.
86 CJ7 258 (1st Jeep and loving it)
Dana 44 rear
35 MTRs with 5 inch lift
Powertrax lockers front and rear
Re: Power Brakes Question [Re: brightray] #507873 10/11/04 06:35 PM
Use a manifold vacuum port. Try not use the carb vauum.
Carb produces less vacuum and low idle, manifold is greater and low idle. This will work perfect when wheeling and street use.
Re: Power Brakes Question [Re: Junkie] #507874 10/11/04 07:42 PM
doc long Offline
in this picture....
http://home.sprynet.com/~dale02/egrvalve.htm
the brass fitting with the threaded plug directly above the
egr is the stock connection point for the power brake setup
Re: Power Brakes Question #507875 10/11/04 07:51 PM
you are talking about proted vacume. alot of carbs have a stand off plate with a huge manifold vacume plate. i beilieve he is refiering to the plate.
Re: Power Brakes Question #507876 10/11/04 08:26 PM
Gotcha, I missread the post.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6041 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-06-22 06:02:38 UTC
