Power Brakes Question
#507870
09/30/04 02:24 PM
Installing power brakes on my 86' CJ. Have a 6cyl. w/ a Weber Carb. Where can I pull vacume from? If you have a picture that's even better, unless it's pretty obviouse. There is no provision on the carb base as is on say a Ford 302. Any help would be greatly appreciated. Thanks in advance!
Re: Power Brakes Question
[Re: Junkie]
#507871
09/30/04 06:58 PM
i'm not sure about the manifold on your jeep... but if it doesn't already have a port thats been sealed.. i've seen people pull the manifold and drill and tap a new port for the booster.
[Re: Junkie]
#507872
09/30/04 11:06 PM
On my Jeep I have a port on the carb adapter that came with my Weber carb. You must have a different manifold than I do. My jeep is an 86 also with the stock manifold.
86 CJ7 258 (1st Jeep and loving it) Dana 44 rear 35 MTRs with 5 inch lift Powertrax lockers front and rear
[Re: brightray]
#507873
10/11/04 06:35 PM
Use a manifold vacuum port. Try not use the carb vauum.
Carb produces less vacuum and low idle, manifold is greater and low idle. This will work perfect when wheeling and street use.
#507875
10/11/04 07:51 PM
Carb produces less vacuum and low idle, manifold is greater and low idle. This will work perfect when wheeling and street use. you are talking about proted vacume. alot of carbs have a stand off plate with a huge manifold vacume plate. i beilieve he is refiering to the plate.
#507876
10/11/04 08:26 PM
Gotcha, I missread the post.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6041 MB (Peak: 0.6813 MB) Data Comp: Off Server Time: 2026-06-22 02:41:03 UTCValid HTML 5 and Valid CSS
