1994 Pickup question #508332 10/01/04 07:44 PM
hunterdan Offline OP
Normally I stay over on the Isuzu boards, but I have a quick question on a 94 pickup. Im looking to buy a newer truck, Im having tranny problems on my rodeo, which is pushing this now rather than later. But I stopped at a dealer, and saw a 94 pickup, it has the extended cab, shortbed, manual hubs. Its a 4 cyl 5 sp with 75000 miles. My question is, what would you expect to pay for this. They were asking $9995, which when I heard that almost fell over. I know they hold their value, but 10,000 for a 10 year old truck seems kind of high. It has some minor rust and corrosion on the frame. Mainly just paint flaking off. I did a MBB retail and it said about 7500 for it. I then did a private party and came up with 5500. I still have to take it for a ride. But, it looks to be in good shape, no rust on the body, has a bed liner. What would you guys pay for it. Thanks for your help.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: 1994 Pickup question [Re: hunterdan] #508333 10/01/04 07:48 PM
Esquire812 Offline
Pull the bedliner up and check the rustification level under it...trapped water has a tough time evaporating when covered over. I wouldnt pay more than high retail for the rig...if the dealer expects more they are obviously higher than a well nevermind. You know damn well they didnt pay more than low trade in for the truck in the first place....dicker them down after a test drive...also make them perform a bumper to bumper maintenance as part of the deal.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: 1994 Pickup question [Re: Esquire812] #508334 10/01/04 07:55 PM
Thanks for the quick reply. I'll be heading back up tomorrow after I get out of the woods. The trade in value on it is listed at around $3800. Is there anything else I should watchout for besides rust? I know the motors are reliable. But how well does the 4 cyl move these trucks? Im not looking for a speed demon by any means, but dont want to be embarrassed going up mountains. How well do the transmissions hold up? If things work out, I may be switching sides here and joining you guys. The surprising thing is that the tires looked almost brand new. Although I have a set of rims at home that have 31's sitting on that may fit. Thanks again
Dan
Re: 1994 Pickup question [Re: hunterdan] #508335 10/01/04 07:58 PM
Stan_Marshall Offline
that's wayyyyy too much. $5,500 would be closer to a good price.
i paid $5,000 for a 94 regular cab 22RE (4 cyl)/W56 (5 speed) in good shape with 84,000 in cleveland (which isn't too terribly far from you) last june. (and it had a fiberglass bed cap that was also in very good shape.) and four nearly brand new ATs. I got it from a private party, though.
i'd shop around some more...especially looking at private parties...if i were you.
good luck.
stan
1994 4x4 22RE W56 truck
Re: 1994 Pickup question [Re: Stan_Marshall] #508336 10/01/04 08:03 PM
Thanks again. Id prefer to get it through a dealer just so I might get like a 1000 mile warranty or so. I talked to my dad and he said I might as well trade my truck in.
Dan
Re: 1994 Pickup question [Re: hunterdan] #508337 10/01/04 08:10 PM
well, if you do get it...
a big thing to watch out for is the timing chain. the stock guides are made of plastic and the driver's side guide will eventually break. this won't be a disaster if you catch it in time. however, eventually, without the guide in place, the t-chain will wear through the t-chain cover and into a water passage...not good.
if they'll let you pull the valve cover off...or pull it off for you...you can just look down the front of the engine to see if the guides are still there and unbroken. otherwise, start it up...rev it to about 2500RPM and listen for a rattle coming from the front of the engine. that is a tell-tale sign that the t-chain is hitting the t-chain cover.
changing the t-chain is not a big deal...$50 to $100 in parts, depending on whether or not you need a new cover...and 4 to 12 hours in wrenchin' depending on how quick you are.
other than that, they seem pretty rock solid.
i have no issues with power. i have only 30" tires, though. and i have the regular cab which is prolly a bit lighter than the x-tra cab. it's no drag racer, but i can merge onto the highway without problems. i've carried well over 1/2 ton of dirt/gravel/etc. in it at various times up some pretty steep hills without problems, too.
my tranny rattles a bit at certain RPMs, but it shifts fine and seems to be quite strong. no metal flakes in the oil or anything.
it's a great truck...i just think you could prolly get one cheaper.
stan
Re: 1994 Pickup question [Re: Stan_Marshall] #508338 10/01/04 08:16 PM
oh, by the way, welcome to the right side of the 4x4 fence <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 1994 Pickup question [Re: Stan_Marshall] #508339 10/01/04 09:00 PM
Esquire812 Offline
Yeah do like Stan the man says, put your finger into a couple of holes before shacking up with any of them. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Wont hurt to play with the dealer and at least find out if they are in a position to "discuss" the truck and asking price. If they play hard ball, do a 180, drop trou and show them what you think of their business practices. (Notice he aint driving so this is perfectly good advice and safe too).
Private party will give you the best deal because most people dont have markup and overhead....some need food on the table and others have a new payment that needs taking care of. Shop before you buy....took me over a year to find my 4Runner in the condition I wanted (needing help) for the price I was willing to pay (still too much <img src="/forums/images/graemlins/rolleyes.gif" alt="" />).
85' Sillyca 22R-Esq
Re: 1994 Pickup question [Re: Esquire812] #508340 10/01/04 09:11 PM
HawkFanatic Offline
june of 01 I paid 7500 for my truck with 39k on it.
it was more than I wanted to spend, but the truck was an absolute bone stock VIRGIN!! I could still see the check marks on the gas tank from the factory...
One timing chain and starter later, I couldnt have bought a new truck as reliable.. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1994 Yota 4x4 Short cab
5spd 22RE
Mostly Stock, but I'm learnin'!
31x10.50s
Re: 1994 Pickup question [Re: Stan_Marshall] #508341 10/01/04 10:34 PM
Red_Chili Offline
Toyota Section Staffer
Not generally at only 75K miles... more like 120K-150K. They usually let you know audibly before doing much damage.
-Bill
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6427 MB (Peak: 0.7700 MB) Data Comp: Off Server Time: 2026-06-07 00:50:11 UTC
