Re: Where do you stow your spare tire in a 1st gen 4Runner? [Re: abnormaltoy] #508497 10/04/04 07:45 PM
ErikB Offline
Toyota Moderator
I ran a 34x9.5" swamper as a spare in the stock location for a few years w/o problems. It didn't hang down much lower than my Smittybilt bumper.
pic
When I built a new rear bumper I started carring a full size (35x12.5") spare inside, strapped vertically to the roll bar.
Now with 37's, I'm not sure what I'm going to do. Last trip I just laid it flat and strapped it down in the cargo area, but it really takes up a lot of space. I may build a rear carrier, but I don't really want to have that big thing hanging off the rear and loose the visibilty... <img src="/forums/images/graemlins/pfft.gif" alt="" />
http://home.4x4wire.com/erik
Re: Where do you stow your spare tire in a 1st gen 4Runner? [Re: ErikB] #508498 10/04/04 11:35 PM
4
4RnrRick Offline
My 4runner is bobb'd 9" and a 35" 12.50 BFG fit back there snuggly! Now, I'm on 36" IROK's and there was no way I could get it to fit into the back cargo area due to the Bob. So I made a rear tire carrier. Only problem is that I have a Can-Back and no Side windows and it took up all my view. So I didtch that and retrofitted a pickup tailgate in place of the 4runner tailgate which gave me 4+ more inches of cargo area. so now my 36" Spare IROK sits flat in the back. BTW, I't strapped down using the rear seat latch bracket and the old tail gate latch brackets. Now the only problem I have is I can't find a long skinny tool box for my longer tools......
Project Quasimodo
'85 Xtra Cab (2wd, 22RTE, Auto => 4wd, 3RZ, w56, 2.28x4.70)
Re: Where do you stow your spare tire in a 1st gen 4Runner? [Re: 4RnrRick] #508499 10/05/04 12:47 AM
Strange nobody has the spare on the roof?????? I am getting ready for a 3k + mile trip through Mexico and I am taking a second spare that will be on the roof with fuel and water cans.
Re: Where do you stow your spare tire in a 1st gen 4Runner? #508500 10/05/04 04:59 PM
Wow! 3k through Mexico, sounds like fun!!Be careful go'n around corners. Don't tip over! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Where do you stow your spare tire in a 1st gen 4Runner? #508501 10/06/04 04:02 AM
Will try and keep all wheels on the ground unless intended.
Spare 100#'s
40l of liquid 80#'s roughly
Re: Where do you stow your spare tire in a 1st gen 4Runner? [Re: abnormaltoy] #508502 10/06/04 01:35 PM
DO NOT use the factory "D" rings in the cargo area! I'm the one that BIGBRI was talking about. I got beaned by a 32x11.50 traveling at 55 mph. It's the only time in my life I've ever been knocked out. A tire/wheel combo can easily weigh 100lbs, you don't want that flying around the cab!
Can you say more about that? Did the D rings break, or what? I keep stuff ratchet-strapped back there using the D rings, and I'd hate to think I'm driving around with a false sense of security. Thanks.
Re: Where do you stow your spare tire in a 1st gen 4Runner? #508503 10/06/04 02:19 PM
Red_Chili Offline
Toyota Section Staffer
Make a big fat reinforcing plate for each ring beneath the floor and it should be just fine. Use fatter rings if you want more.
Tires are extremely heavy, hence the risk. That's why I won't run one on the roof; exactly the wrong place to put a lot of weight. For normal cargo I would not worry. Still, strapping to the rollbar is always a good idea.
-Bill
Re: Where do you stow your spare tire in a 1st gen 4Runner? [Re: Red_Chili] #508504 10/07/04 11:52 PM
BigBri Offline
Hmmm, I'm not sure where Abnormaltoy went... so I'll try to answer. If I remember correctly, on his factory loops, what gave out was the D-ring itself. It is not a complete, welded, loop. Instead, the portion of the ring that you can't see, that goes into the clamp, just has an unwelded seam half way across the back of the D. With enough force the D-ring will open up and pop out of the clamp. I'm pretty sure thats what happened to Abnormal. Those tiedowns aren't as strong as they look. <img src="/forums/images/graemlins/frown.gif" alt="" />
Later, B.
Re: Where do you stow your spare tire in a 1st gen 4Runner? [Re: BigBri] #508505 10/08/04 12:42 AM
abnormaltoy Offline
'zactly right! My "D" rings looked more like this "[". The tie down came right off the end of one ring, held on the other...the journey terminated at my head. Which was made worse by the fact that my seat bent backwards, not reclined, the seat frame folded! Those who knew me before say I'm different now! <img src="/forums/images/graemlins/smile.gif" alt="" />
I would rather suffer the consequences of a Conservative?s error, than suffer the consequences of a Socialist's intent.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6265 MB (Peak: 0.7450 MB) Data Comp: Off Server Time: 2026-07-16 13:24:56 UTC
