22RE help #508886 10/03/04 03:25 AM
Stomper Offline OP
Can someone tell me how hard it is to change the rear main and front main seals? I understand T-case and tranny for the rear and rad and stuff's got to come off. But do I got to drop the pan and crank?
1985 4runner
Re: 22RE help [Re: Stomper] #508887 10/03/04 03:56 AM
Esquire812 Offline
Nope, leave the pan and crank in place. For the rear main you will have to go farther than trans removal, clutch assembly and flywheel will need to come off as well to access the rearmain carrier/retainer. The two rear most oil pan bolts will have to be removed because they screw into the retainer...which is bolted to the block with 5 12mm bolts (M8x125x16 comes to mind). Front is even easier, shouldnt have to remove the radiator to get the crank pulley off. Once that is done, simply pull the oil pump, push the old seal out from behind...tap new one in place and reassemble. If you notice a groove worn in the crankshaft pulley where the seal rides (on the crank itself for rear) you will need to sleeve-n-seal them or your work will be worthless.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: 22RE help [Re: Stomper] #508888 10/03/04 03:58 AM
Y
yota89 Offline
No you dont have to drop the crank or oil pan, but you will have to remove your clutch and flywheel, and the 2 back bolt of the oil pan. You can use some FIPG sealer where the seal retainer fits up to the oil pan, if you remove the reatainer. The front seal it pretty easy, just remove the needed accesories and crank pully, pop out old seal and install new seal.
Good Luck
89 yota pickup
22RE 261C cam
Tanny / engine rebuilt after 256K
Head machined to RV street spec(EB's)
Re: 22RE help [Re: Esquire812] #508889 10/03/04 04:57 PM
Stomper Offline OP
"If you notice a groove worn in the crankshaft pulley where the seal rides (on the crank itself for rear) you will need to sleeve-n-seal them or your work will be worthless."
This is a new one on me how do you sleeve and seal? Also what parts would I need to do a sleeve and seal. When I do this I wana make sure I have the parts I need.
1985 4runner
Re: 22RE help [Re: Stomper] #508890 10/03/04 07:01 PM
Esquire812 Offline
Sleeve-n-seal is a metal piece resembling a cross section of a soda can, very thin but perfect surface. The seals on the 22R-E crankshaft are spring tensioned and over time dig into the sealing surface creating a groove. This is why they leak in the first place. Simply clean the area then tap the sleeve over the crank or over the front pulley shank for the front and the sealing surface is restored.
Engnbldr sells the sleeve's for like $20 for the pair. If you look in the part # thread over in the 4x4 section you can find individual part #s for Felpro I think to purchase at local parts store. Some places have to special order...I just order mine from Ted anytime I have will have an engine apart. IF its not sleeved before my stinky hands get on it...it is shortly after.
85' Sillyca 22R-Esq
Re: 22RE help [Re: Esquire812] #508891 10/04/04 01:26 AM
Stomper Offline OP
Thanks for your help Im breaking into this 22re stuff with both feet. I Had a Tacoma before and never had to do any motor work on it. So far Ive had to replace the Radaitor, Theromstat, idler pulley bearing for the power steering, Plugs and wires. Now it look like a rear and front main seal. Also got to investagate, Sounds like I got a lifter ticking.
1985 4runner
Re: 22RE help [Re: Stomper] #508892 10/06/04 06:24 AM
kewlynx Offline
...Now also got to investagate, Sounds like I got a lifter ticking.
That ticking simply might be worn valve adjustment screws. They get flat spots on 'em; easy enough to swap out.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6216 MB (Peak: 0.7128 MB) Data Comp: Off Server Time: 2026-11-18 03:40:25 UTC
