More 85 Runner help.
#509542
10/05/04 01:17 AM
If I get on yalls nerves with all the qusestion just let me know. Ok heres the deal I got it and caint do the cross over Hy steer yet cause money has been put into brakes and lots of other crap that didnt show up till I drove it 100 miles to the house. But the steering has lots of play in it, Is there any way that I can tighten the steering box? I know on some old Fords you could and was wondering if I could do the same on this one.
Next, The wife got too looking and asked me if I could put shoulder tpye seat belts in the back for the kids booster seats. I told her that it looked like the roll bar was made for it but was unsure. Does anyone know if this can be done and where I could get the parts to do it?
1985 4runner
Re: More 85 Runner help.
[Re: Stomper]
#509543
10/12/04 10:07 PM
Not sure the steering can be adjusted, but I would check the ball joints for excessive play first. There are some cone type bearings that control the steering in the knuckle area which could be loose or dying, but to be honest, I'm not sure how much it would help. (Had a friend who knew this stuff assemble mine when I did my rebuild). As for the seatbelt issue, I've had the exact same thought, but haven't invested much time or energy into investigating it further. In theory, you could find any shoulder harness that would clip in (another toyota donor part would work), and weld a nut to the roll bar (possibly have to drill out the bar first), and just attach it. Not sure if that little plastic piece hides a mounting point for a shoulder harness. <note to self> hmmm, ought to check that out </note to self>
Good luck, and let me know if you find anything good
Erik <img src="/forums/images/graemlins/cheers.gif" alt="" />
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did.
85 4Runner, New motor, Dual cases, 4.88's, ARB's (F/R), 4" lift, 33's, Warn M8000#.
[Re: Stomper]
#509544
10/13/04 12:18 AM
Ball joints? <img src="/forums/images/graemlins/lol.gif" alt="" />
First check the drag link, they can get real sloppy. Then the tie-rod ends. Then the wheel and knuckle bearings. If you did the brakes you may have had the rotors off and redone the wheel bearings already. I think there is an adjustment on the steering box that can take out a little play, just don't overdo it.
[Re: Germ]
#509545
10/13/04 11:37 PM
I was in the wrecking yard today, and found one of the 4runners with that little plastic piece taken off, and lo-and-behold there is a threaded nut welded in place (just as I figured). Looks like it should be a bolt up type job. Not sure about the floor mount, but I'd imagine you could just use the stock mounting holes.
#509546
10/14/04 03:17 AM
Ill check the wheel bearing and Ball joints. Also I saw a thing on Rogers site that talked about how hard the drop draglink is to get set up right, So im going to check that too just incase someone goofed it up when they put it in.
Thanks for the reply.
1985 4runner
[Re: Germ]
#509547
10/14/04 03:19 AM
My plastic pices are off too and I saw the bolt and got to thinking about it. I may see if I can get some belts to fit in there.
1985 4runner
