LIFTING FRONT OF 90 MIGHTY MAX #509899 10/05/04 09:19 PM
I was wanting to know if there was a place to get a suspension lift for the front of my 90 Mighty Max, 3.0.
I have yet to find anyone that sells a kit for this and I dont have time to make one. <img src="/forums/images/graemlins/frown.gif" alt="" /> My torsion bars are cranked and I have a 3" body lift on it but, I still cant fit my 33" tires. They hit the fender flares and inner fender well on the front. I can only turn enough to make a 50 point turn around <img src="/forums/images/graemlins/shocked.gif" alt="" />. Any help would be great. Thanks
Re: LIFTING FRONT OF 90 MIGHTY MAX #509900 10/05/04 09:25 PM
Are you using the same/stock rims or one with a different offset/backspacing?
Re: LIFTING FRONT OF 90 MIGHTY MAX #509901 10/05/04 09:27 PM
mwhite Offline
nobody makes a lift that I know about.
Nathanc is running 33s, I believe he did a
little trimming to fit em. I had to do
some trimming to fit mine. as far as the
fender flare goes I used a heat gun to
reshape an cut.
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: LIFTING FRONT OF 90 MIGHTY MAX [Re: mwhite] #509902 10/05/04 11:28 PM
powerRam50 Offline
with a sawzall you can fit 35's.have you trimmed the upper bump stops.if you trim the upper bump stops you can get onther
inch in tb crank.
Re: LIFTING FRONT OF 90 MIGHTY MAX [Re: powerRam50] #509903 10/06/04 03:14 AM
highmtndesert Offline
I just put a set of 33's off my Raider onto my Arrow. I trimmed the fender just a bit, Think that more trimming is going to be needed.
A body lift is also in the works. I have tried to stuff the tire the best I can around the yard, and I still get a bit or rub on the back of the fender. Playing around on the ramp that goes to the trailer tells me that I really need some traction devices.
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
Re: LIFTING FRONT OF 90 MIGHTY MAX [Re: highmtndesert] #509904 10/06/04 05:37 AM
cragdweller Offline
I'm running 33s on my 94 Mighty Max with no body lift and only about 1.5" of torsion bar lift. I did some minor nip and tuck type trimming on the edge of the front bumper and at the front corner of the cab. There is NO rubbing even at full stuff with wheels cranked either way to full lock. The key is to use wheels with the proper backspacing. I have posted the backspacing measurements before, try a search. 15"x7" Toyota steel spoke wheels are perfect.
1994 3.0L 4x4 pickup.
4.62 gears (4.22 stock), 33x10.5 BFG MTs. LSD rear. Five speed trans. 172K
Previously owned Mitsubishis:
1986 2.6L 4x4 Mighty Max, 1985 2.6L 4x4 D50
1987 2.6L Raider, 1989 3.0L Raider
1995 Montero SR
Re: LIFTING FRONT OF 90 MIGHTY MAX [Re: off-roader] #509905 10/06/04 01:47 PM
The stock rims and 31's are on the truck now but the 33's are on 10" wide rims...that is probably the problem but I like the look of that wide of rim and tire on the truck.
Re: LIFTING FRONT OF 90 MIGHTY MAX #509906 10/08/04 02:32 AM
NathanC Offline
Like above, I had to do a little trimming and shaping of the rear of the fender. Have you thought about swapping gears? Where in Illinois are you?
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: LIFTING FRONT OF 90 MIGHTY MAX [Re: NathanC] #509907 10/08/04 06:38 PM
I am right outside of Springfield.
I have never gave thought about swaping gears..all I want is my tires that I have sitting in the garage to fit <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: LIFTING FRONT OF 90 MIGHTY MAX #509908 10/08/04 08:15 PM
Don't know about the fender flare's but some options have been posted regardng "re-forming" them.
For the inner fender rubbing, try using wheel with a different offset that brings the tires further out.
I don't recall if Don's offset diagram shows actual measurements but if they do, then perhaps you can use them to figure out what offset you'll need.
Or you can temporarily put spacer's on to figure out how far out they need to be then replace the rim's with one that has the correct offset.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6290 MB (Peak: 0.7361 MB) Data Comp: Off Server Time: 2026-11-16 01:19:48 UTC
