Weber guru's #510136 10/06/04 05:03 AM
Toybluggie Offline OP
My stock carb was stalling and I got sick of fussing w/it so I bought a new 32/36. I know the truck now wont pass the CO smog test, which is okay. But, I cant have any visible smoke from the tail pipe, which I do! Black, caustic stuff that makes the soccer moms roll up their windows <img src="/forums/images/graemlins/evil.gif" alt="" />. But its mainly visible upon WOT(quick puff). Is this just an affect of the 32/36 or is there something I can do? Thanks for the help.
JT
84 22re pickup
Re: Weber guru's [Re: Toybluggie] #510137 10/06/04 05:28 AM
re check your mix.. but u could have just alot of carbon built up in combustion chamber check you plugs buddy and try a sea foam. im nto real sure how to use the sea foam maybe someone will chime in on it. how ya like the carb? i have a 32/36
JT
Re: Weber guru's #510138 10/07/04 03:02 AM
kyle-22r Offline
plain water also works for blasting out carbon from the valves and stuff. use a very small(too big and you'll hydrolock -- i've heard of guys using the brake booster hose and it caused some snapped rods <img src="/forums/images/graemlins/shocked.gif" alt="" /> ) vacuum line and suck in some water through it in small amounts
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Weber guru's [Re: Toybluggie] #510139 10/07/04 04:15 AM
I just replaced my plugs maybe a month ago, but I havent checked em since the weber install, will do tommorrow. When I removed the EGR it was totally plugged, from the valve to the manifold, so Im gussing I have carbon clotting in other spots too. What is this "sea foam" you speak of & how does it work? So far I like the new carb, but my MPG has went in the toilet. I like to hear the sucking sound and the burrrr of the barrels at WOT. I can do 75 again <img src="/forums/images/graemlins/smile.gif" alt="" /> I get to 3rd alot faster than I used to, but after that Im a turd in the gutter. I dunno about squirtn H2O into the box, I dont want to let pandora out. Biotch is mean.
JT
84 22re pickup
Re: Weber guru's [Re: Toybluggie] #510140 10/08/04 03:22 AM
SHAD Offline
Goto www.carbsunlimited.com and look at the weber carburetor setup it tells you everything you need to know how to set it up and tune it.
a direct link: www.carburetion.com/weber/adjust.htm
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: Weber guru's [Re: SHAD] #510141 10/08/04 06:22 AM
Thanks for the link, its going into my favorites list. All 4 of the plugs had nice Carbon coats. Cleaned em off real good, then retuned the mixture and idles. No more [color:"black"] [/color] black smoke <img src="/forums/images/graemlins/smile.gif" alt="" />. Thanks for the info.JT
84 22re pickup
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6089 MB (Peak: 0.6797 MB) Data Comp: Off Server Time: 2026-06-13 10:51:45 UTC
