New front main seal leaking! #510474 10/07/04 12:57 PM
solarcrew Offline OP
<img src="/forums/images/graemlins/confused.gif" alt="" />I've heard you folks talk about adding something to a front main oil seal to stop it from leaking when replaced on an older motor.What's it called and where can I get one?My new seal is leaking a drop or two after running!Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
87'4runner-22re,5spd
Re: New front main seal leaking! [Re: solarcrew] #510475 10/07/04 01:03 PM
Y
yota89 Offline
If your thinking about the sleeve and seal from Engnbldr that will help, if there was a groove worn in the crank pully. I think the kit was 15.00 for a front and back sleeve.
89 yota pickup
22RE 261C cam
Tanny / engine rebuilt after 256K
Head machined to RV street spec(EB's)
Re: New front main seal leaking! [Re: yota89] #510476 10/07/04 02:54 PM
G
GeriatricToy Offline
It is called a sleeve. I've heard nothing but good things about engnbldr and plan on purchasing some valve adjusting screws from him. This three hour time difference thing is messing me up as far as calling in the order though.
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: New front main seal leaking! [Re: GeriatricToy] #510477 10/07/04 09:53 PM
Esquire812 Offline
Email him with your order! You can do that, call or even mail in your order...but it is kinda fun to rattle his chain on the phone. <img src="/forums/images/graemlins/smile.gif" alt="" /> Last I heard he was out of the screws, trying to trackdown a supplier...but ask him for the skinny...I could be blowing hot air up your....nevermind. LOL
For the orignal poster Mister Solarcrew...if its leaking after installing a new front main seal, chances are these boys is correct. Crankpulley gets grooved from the seal spring...result is a mess up front of the engine...and as time passes a mess of the engine compartment and underside of your truck. Makes for great corrosion protection..but looks like crap.
I'll see if I can find any pictures of the problem and cure. Alternative to a sleeve is to not seat the seal fully into the oil pump thus causing the spring to ride forward of the groove on the shaft....but this isnt the proper way to handle it...hell even I dont shortcut it this way.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: New front main seal leaking! [Re: Esquire812] #510478 10/08/04 01:13 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> Darin,you are the man!Thanks to all of you!Already ordered the kit from EB and he sent it out priority!Did it all today.If you can find the pic,I'd still like to see it.later dudes! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: New front main seal leaking! [Re: solarcrew] #510479 10/08/04 08:07 PM
The sleeve looks like someone cut the bottom 1/3rd off of a Coke can. One side has a lip on it. I installed mine by putting the sleeve on as far as I could with hand strength (which is pretty strong on my right hand, <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> ) and then I sat the crank pulley on the flat garage floor (sleeve side down) and then put a board on top of the pulley, and hammered the poop out of it until it slid on all the way.
Re: New front main seal leaking! #510480 10/08/04 09:49 PM
<img src="/forums/images/graemlins/lol.gif" alt="" /> Thanks Ben!I just hope the right hand is up to the task.I'd never get it on with the left hand.Kind of a weak grip,mite slip off and hurt myself. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: New front main seal leaking! [Re: solarcrew] #510481 10/09/04 12:42 AM
Esquire812 Offline
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
85' Sillyca 22R-Esq
Re: New front main seal leaking! [Re: Esquire812] #510482 10/10/04 12:47 AM
<img src="/forums/images/graemlins/confused.gif" alt="" />Just got home and found my new sleeve kit on the kitchen counter.Like Ben said,one side has a lip on it.Which way should the lip face?Toward the block or toward the rad?I don't wanna mess this up!Thanks for any replies! later,Doug <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: New front main seal leaking! [Re: solarcrew] #510483 10/10/04 01:39 AM
Y
yota89 Offline
Well if you can get it on lip first, make a video so I can watch. <img src="/forums/images/graemlins/smile.gif" alt="" /> For real though the lip should face the (edit block) for the front and the lip on the rear will face the fylwheel. Heres a Pic Of my crank I just sleeved. [Linked Image]
You'll be set in not time now.
GoodLuck
89 yota pickup
22RE 261C cam
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6345 MB (Peak: 0.7583 MB) Data Comp: Off Server Time: 2026-11-01 22:58:07 UTC
