Page 1 of 4 1 2 3 4
4.875 Gears #510743 10/08/04 03:50 AM
highmtndesert Offline OP
I called the local Dodge dealer today,looking for 4.875 gears.
I had them look it up for a 87 Dodge Raider. I was told they only listed 4.625, and they were not available.
What I have read here on the wire ,is that they came in High altitude models. High Altitude models of what? Are they available for the 2.6? Has anyone ever seen a high altitude model?
PowerRam50 you found a set, What were they in?
I really need to find a set of these gears, As I can not get 4.625 for the front of my truck.(Dana 30) But I can get 4.88
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
Re: 4.875 Gears [Re: highmtndesert] #510744 10/08/04 04:02 AM
DougH Offline
Mitsubishi Forum Moderator
I will try to look it up for you later tonight, or at the latest tommarow morning. I will get you a part number either way.
DougH
1995 SR - RIP
1993 RS - RIP
Re: 4.875 Gears [Re: highmtndesert] #510745 10/08/04 04:06 AM
A
AcidophilusRex Offline
The 2wd '86 Ram50 I had was a high-altitude model...but I'm not sure what differentiated it from the low-altitude models, though presumably it was stuff like carb jetting and timing. I don't think the gearing was any different (it had great highway gearing) but then, it was only a 2wd.
I've always heard that the 4wd trucks and Monteros (high-altitude) had the 4.88 gearing, but I've nothing to support it.
Re: 4.875 Gears [Re: DougH] #510746 10/08/04 04:06 AM
DougH Offline
Try:
MB185458
MB527147
DougH
1995 SR - RIP
1993 RS - RIP
Re: 4.875 Gears [Re: DougH] #510747 10/08/04 04:09 AM
DougH Offline
Or: MB241968
DougH
1995 SR - RIP
1993 RS - RIP
Re: 4.875 Gears [Re: DougH] #510748 10/08/04 04:17 AM
Thanks I wll try those #'s at the dealer tomorrow.
With the 3.90s and 33's I have not been past 3rd gear yet. But it is way slow on take off. I could probably drive all around town in low range.
Re: 4.875 Gears [Re: highmtndesert] #510749 10/08/04 05:00 AM
LandRaider Offline
Dude!!! 4.56's in the front!!!
Thats what I am using!!
AND BobShaw has 4.56's in the rear(toyota Axle), and 4.62's in the front.
Not enough difference to matter!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
DOOOIT!
Re: 4.875 Gears [Re: DougH] #510750 10/08/04 05:09 AM
84 monty had std diff for 5spd 4.625, optional 4.875 federal only, a/t 4.22, optional 4.625 federal only. No info on ring gear diameter there, though.
Re: 4.875 Gears [Re: LandRaider] #510751 10/08/04 05:20 AM
Curtis, If that works OK then I may just have to go that way.
I already have a 4.625 with a LSD sitting on the ground. I may save the LSD and just put a lincoln to the rear. Or save even more and lincoln the front too. This truck is going to be trail only,And Im sure that I will break it soon enough.
Re: 4.875 Gears [Re: highmtndesert] #510752 10/08/04 05:22 AM
powerRam50 Offline
found my set in a 86 monty 2.6 5 speed.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6429 MB (Peak: 0.7620 MB) Data Comp: Off Server Time: 2026-11-02 04:00:43 UTC
