Axles #512650 10/12/04 09:43 PM
rebelboydylan Offline OP
My dana 35 axle broke and i need to get a bigger axle is there any junk yard axle like a dana 44 that would bolt right up?
91 yj renegade with 4.5" lift 33x10.5s wanting to be a rock eatin machine
Re: Axles [Re: rebelboydylan] #512651 10/12/04 11:26 PM
the only axle that will bolt up is another dana 35c. all other axles will need some degree of work unless you order one from a company like pro rock or curry. any other axle will need modifications some where, the most common will be converting from spring over to under.
Re: Axles [Re: rebelboydylan] #512652 10/12/04 11:27 PM
kobyhud Offline
You are going to get a lot of answers on this one.
But for starters we need some more information.
What is your current gear ratio??? Do you want to lock it at the same time? How serious are you?? What do you use it for? Would a limited slip suffice?? Etc...
A little information can go a long way.
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: Axles [Re: kobyhud] #512653 10/13/04 02:22 AM
superdawg Offline
Comanchee d44 is the closest to "bolting up"
Just the spring mounts need to be cut of and new ones welded on.
Call mitch at RMH he has a few of these for sale.
303-808-1268
SD
Re: Axles [Re: kobyhud] #512654 10/13/04 02:23 AM
Macka Offline
I am sure some of the guys who still have 35's hanging around their shop/yard after doing a swap would be able to help. IMO if you have the $$$ get a 44 upgrade done.
always working
Re: Axles [Re: Macka] #512655 10/13/04 02:56 AM
i have a 91 wrangler with a 4.5 suspention lift and 33x10.5 i'd say i'm off roading 25% of the time other on road this is my second 35 i'v went through i'd like to put a dana 60 in or a ford 9" but time is a issue for this project
Re: Axles [Re: rebelboydylan] #512656 10/13/04 04:11 PM
kobyhud Offline
for a Dana60 or 9" it is going to be a job or lots of $$$s. The axles will have to be narrowed, most likely you could match up a gear ratio but it really isnt going to matter because its going to have to be pulled apart to narrow it anyway.
To find something with your current gear ratio I would look for a Wagoneer 44 that is a little wider and has disk brakes. Common ratios here are 3.73. This is probably the easiest option.
If you were willing to regear the front as well you could find an isuzu 44 with a G80 (chevy/GM) limited slip for pretty cheap. This would be a great width but the gears would be either 4.10 or 4.30. Which wouldnt be bad if you could find a Dana30 from a 4cylinder Wrangler with the 4.10 gears. You could be out the door with lower gears and a limited slip for less than a grand if you went with this route with disk brakes as well.
Re: Axles [Re: kobyhud] #512657 10/13/04 05:17 PM
Actually a Waggie rear is a little bit narrower. His 35 is 60" and a Waggie 44 is about 58". The wheel pattern will be different than the front axle though. A Ford 8.8 out of a 95 or newer Explorer has the right wheel pattern and disc brakes to boot. Either one is going to take a bit of fabrication (not hard stuff) to make work.
Re: Axles #512658 10/13/04 10:34 PM
kobyhud Offline
you can find waggies all the way out to 63 inches wide.... you are correct about the wheel pattern... 6on5.5 isnt going to match the front.
The ford 8.8 is just a little narrower like 59", has disks, could have a limited slip as well... another great option probably going to have to regear the front though, but again you could find a 4 cylinder D30 with 4.10s and have a grand old time. lighter than a 44 as well. Axle clearance isnt quite as good, but not enough to really matter.
Re: Axles [Re: kobyhud] #512659 10/14/04 11:44 PM
Not on a rear axle. Waggies are only available narrow track. Front is 62.5" and the rear is about 58". Now a Cherokee Chief or J-truck 44 is wider. Front is about 65" and the rear is about 61". I have at least one set of each in my shop.
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.6278 MB (Peak: 0.7358 MB) Data Comp: Off Server Time: 2026-11-18 11:45:27 UTC
