Stabilizer bar drop bracket
#512789
10/13/04 03:33 AM
Does anyone know if a drop bracket is available for the rear stabilizer bar on the 3rd gen 4Runner to re-align the axle after installing a lift? I've had my truck lifted for over 2 years now and although I've had no problems I seem to be noticing lately that the axle is certainly shifted to the passenger side. I'm thinking of adding more lift but that would shift the axle over even further.
2000 4Runner, OME 882 front coils w/ firm shocks, 891 rear coils w/ firm shocks, Sonoran Steel adjustable rear panhard bar, ARB Prado bullbar, Warn 9,000lb. winch, Amsteel synthetic winch line, Hella Lights, 265/75R16 BFG All Terrains
Re: Stabilizer bar drop bracket
[Re: Deron]
#512790
10/13/04 03:06 PM
Toyota Moderator
Something like this? Do a search on panhard drop bracket, you should find something. You will need to have it welded though.
Bill 97 SR5 4WD Yukon 4.88s, ARB locker front/rear, OME Lift w/ Cornfeds, 2 Body lift, Panhard drop, Custom gauges, Nuke discos, TJM T17, My Runner
[Re: Wild_Bill]
#512791
10/14/04 02:40 AM
Yep, something like that. I meant panhard rod drop bracket. I know that drop brackets are available for 2nd gen 4Runners and they're bolt-on, no welding required. Any special reason why they need to be welded on the 3rd gen? Just curious.
[Re: Deron]
#512792
10/14/04 06:26 AM
