Re: Steering adjustment? #514338 10/16/04 10:21 AM
4
4xGeek Offline OP
I've got a good .75" of play in the steering... I remember someone posting something a while back about tightening up the steering, but I can't seem to find it... <img src="/forums/images/graemlins/confused.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Steering adjustment? [Re: 4xGeek] #514339 10/16/04 10:04 PM
Kookadala Offline
Havnt looked at the T but on other cars I know there is a bolt and nut on top of the steering box. If you loosen the nut, then turn the bolt in a little bit while someone else wiggles the steering wheel, you can get rid of the slop. Then hold the bolt in place while you retightn the nut. If you dont hold the bolt from turning while you tighten the nut, you can overadjust and cause excessive wear or binding.
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Steering adjustment? [Re: Kookadala] #514340 10/16/04 10:16 PM
4
4xGeek Offline OP
Cool, thanks... Seemed to remember it was something like that but wasn't sure. I'll give that a shot. <img src="/forums/images/graemlins/kewl.gif" alt="" />
4xGeek (Chris)
Re: Steering adjustment? [Re: 4xGeek] #514341 10/18/04 05:29 AM
N
Nodelk Offline
On the top of the box there is a nut and a slot in the top of the bolt, loosen the nut and turn the bolt w/ a screwdiver. Adjusting it is somewhat of a pita, being the radiator overflow tank sits right on top. I adjusted mine awhile back, it did help a little. Make sure you hold the screwdriver tight while tightening the nut. The nut locks your adjustment. I still have some play but it is not nearly as bad as it use to be.
'95 T100 Xtra Cab 4x 3.4 Ltr, Custom brush guard, Raider Canopy, Warn Hubs
DELK it's whats for dinner when you don't fill your tags...No DEer, no eLK. I hate BBQ'ing my tags...they keep bursting into flames!
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6005 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-10-24 04:10:12 UTC
