Remove the transfer case shifter ? #514772 10/18/04 12:48 AM
90amigo Offline OP
I removed the 5 speed from the amigo saturday and want it to go back easy.How do you remove the transfer case shifter?
I found one pressure plate bolt broken and it flying around in there.That is why when I started it up once with the clutch in and it jumped forward,the bolt mark is in the flywheel.Also my rear main seal had a dent in it,thats why its leaking.When someone pulled the motor or trans,they didnt think it needed the 2 top bolts where they meet up.But they did put the water cross over bracket in between the motor and tranny,NICE. <img src="/forums/images/graemlins/angry.gif" alt="" />
I'll be playing at the junk yard for the bolts.
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
Re: Remove the transfer case shifter ? [Re: 90amigo] #514773 10/18/04 01:32 AM
mlclark Offline
Isuzu Moderator
Umm...pull. <img src="/forums/images/graemlins/smile.gif" alt="" />
I ususally find that it comes out easier if you shift it into 4H.
Good Luck,
Michael
Re: Remove the transfer case shifter ? [Re: mlclark] #514774 10/18/04 02:49 AM
CPOM Offline
St.Charles stocks those bolts for a few dollars. I ordered two, they charged me for two, but shipped 6. They said 6 was the minimum order but they only charge you for what you order. Pretty good.
CHRIS
98 Amigo, 92 Pup
Re: Remove the transfer case shifter ? [Re: CPOM] #514775 10/18/04 04:00 AM
Bigpoppax2 Offline
Yeah those bolts were real fun to get to. I can't say it wasn't tempting to not put the very top one back in. I put it in anyway. Now after the body lift it will be much easier the next time.
Re: Remove the transfer case shifter ? [Re: mlclark] #514776 10/20/04 12:15 AM
90amigo Offline OP
UMM Thanks. <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6033 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-06-09 10:01:45 UTC
