interesting startup issue #516570 10/22/04 12:52 AM
Ryan12980 Offline OP
okay, on my vehicross this evening I had an interesting issue. It would turn over and startup, but it would then immediately die, would not idle at all. I could rev it and keep the engine alive if I held the gas down, but as soon as I let off the gas, it died again. Then all of a sudden it just started working like normal. This is the first time this has happened to me. I know that maybe once a month the idle bounces around at startup and requires a quick rev to settle it. Anyone got any clues?
Ryan Christiansen
99 Amigo, 2wd V-6 Auto. 3 torsion lift, ES9000's, Yoko's AT+II 31x10.5R15, Indy 4x steel rear bumper, radio shack cb, diesel antenna.
Re: interesting startup issue [Re: Ryan12980] #516571 10/22/04 07:36 PM
P
pplotz Offline
Your about the 15th person this week with this problem.... your not all buying gas at the same place are you?
I used to have those problems a few years ago... I just stopped buying/going to the cheap gas stations, I've run solid since.
that or do a search for the past two weeks and you'll find lots of different reasons.
Peter
Re: interesting startup issue [Re: Ryan12980] #516572 10/22/04 10:57 PM
I think I've read about this with VXs...I seem to recall something about the fuel pressure regulator. Don't quote me on that though, I only skim through things that don't directly pertain to my rigs. You might have better luck checking out vehicross.info on that one.
Good luck,
Phil
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5911 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-11-03 12:23:35 UTC
