V6 Cyl. Head torque and torque sequence #517536 10/24/04 05:07 PM
triplediamonds Offline OP
Anyone have the cylinder head bolt torque specs and the torque sequence? Thanks for any help.
88 Mitsu Van (L300)
90 Mitsu Eclipse GSX
95 Mitsu Montero SR w/285/75/16 torsion bars cranked about 1.5"
04 Mitsu Lancer Ralliart
81 Datsun 280ZX
96 Dodge Cummins Turbo Diesel (316hp/815ft.lbs)
Re: V6 Cyl. Head torque and torque sequence [Re: triplediamonds] #517537 10/24/04 06:04 PM
FrankR Offline
80 ft/lbs..... you have 4 rows of 2 bolts - as you face the passenger side head, the top bolt of the 2nd row (from the front) is #1 - 2nd is the bolt directly under. Continue in a clockwise spiral, tightening in incremental increases until you reach 80 ft/lbs all 'round.
As you face the driver side head, #1 is the top bolt of the 3rd row (from the front). 2nd in order is the bolt directly under. Continue in a clockwise spiral as above.
No retorque is necessary with the OE style gasket.
Frank
PHP: 7.4.33 Page Time: 0.331s Queries: 15 (0.004s) Memory: 0.5883 MB (Peak: 0.6363 MB) Data Comp: Off Server Time: 2026-06-14 05:01:21 UTC
