Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? #518767 10/27/04 04:56 PM
triplediamonds Offline OP
I was looking at the Swamper LTB's and I saw that you can get them in 34/10.50/15 <img src="/forums/images/graemlins/coolg.gif" alt="" />, Im just wondering if that would be pushing it for fender clearance (off-road). Has anyone used this tire before?
88 Mitsu Van (L300)
90 Mitsu Eclipse GSX
95 Mitsu Montero SR w/285/75/16 torsion bars cranked about 1.5"
04 Mitsu Lancer Ralliart
81 Datsun 280ZX
96 Dodge Cummins Turbo Diesel (316hp/815ft.lbs)
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: triplediamonds] #518768 10/27/04 05:29 PM
sparkem Offline
With a 2 in body lift and torsion bar cranking and spring spacers and the right offset rims, they will fit. I once tried on some 35x16 Boggers on my raider with only a 2 in body lift. They rubbed because they were so wide, the height was good.
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: sparkem] #518769 10/27/04 05:58 PM
Big Blue Offline
I don't know what kind of wheeling you do, but will you have enough gear/power to push them. <img src="/forums/images/graemlins/confused.gif" alt="" /> Also ....Don't plan on driving those LTB's on the street <img src="/forums/images/graemlins/shocked.gif" alt="" />...they are not exactly round, just ask Curtis. <img src="/forums/images/graemlins/smile.gif" alt="" />
My opinion, ...but 35's on a SWB are really pushing the limits of safety on the hi-way, and Not really needed unless you wheel some truely extreme rock. I'm looking for a 34"x 10.5" all-terrain type tire for road use, but I have the power, and gear to push them, and they are not yet? avialable in that size.
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: Big Blue] #518770 10/27/04 07:04 PM
Alex Kogan Offline
You can get 255/85R16 which is aproximately 34x10.50R16. Pretty much all of manufactures make that size.
08 PowerWagon (stock!)
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: Alex Kogan] #518771 10/27/04 07:12 PM
Big Blue Offline
Most of those measure out to be a 33" tsll tire, or at least that is what the tire store said. It would be nice to use the Gn-2 wheels that I have also.
Thanks
Kary
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: Big Blue] #518772 10/27/04 10:56 PM
N
NumLock Offline
They should fit but you may have to trim the corners in order to make turning easy. Your top speed will be like 60 or lower and you gas mileage will suffer. Also you may start snapping u joints and axles shafts in some wheeling conditions. Try it out. No one on this board (that I know of) has done it so trial and error. Oh and tell me if you float.
88 Montero, 2'lift, 31X10.5, front locker.
"Because you're mine, I walk the line."
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: NumLock] #518773 10/28/04 12:39 AM
LandRaider Offline
2 of my 4 33X3.50 LTB's were out of round. Just bad tires.
I have seen LTB's that were all perfect, BUT do not expect that.
those are tall skinnys!! I like them!! Giv Em a try!
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: LandRaider] #518774 10/28/04 02:06 AM
Eddy Adams (Georgia) son ran 34x9.5's I believe (different guy than Fast Eddy) but that was several years ago before his son joined the Corp's. and I haven't seen any posts from E. Adams or his son in quite some time nor do I clearly recall what he did but I recall that his 2door 2.6 monty/raider did not need a body lift to run that setup and I don't believe there were any major clearance issues, but again that was a couple of years ago.
Ray <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: off-roader] #518775 10/28/04 02:21 AM
socalmonty Offline
I know Lloyd runs 35's on his SWB, but he does the wheeling to warrant them, and has the gears to turn them! 33's should be plenty for just about anything short of scaling sheer walls! <img src="/forums/images/graemlins/wink.gif" alt="" />
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: socalmonty] #518776 10/28/04 02:59 AM
I know Lloyd runs 35's on his SWB..
But lets not forget that Lloyd's running a 2-3" suspension lift in back, torqued torsion bars, and a 3" body lift.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6412 MB (Peak: 0.7658 MB) Data Comp: Off Server Time: 2026-06-20 20:26:00 UTC
