Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: NumLock] #518777 10/28/04 04:30 AM
triplediamonds Offline OP
Are you sure top speed will be that low? My v6 seems to have good power I just put new heads on last weekend and when im on the freeway if Im not paying attention ill be doing 75! But Ive done a little more research on those tires it seems that they measure 33.6X9.25x15 so they are pretty close to a 33. Thanks for all the input e1 <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Mitsu Van (L300)
90 Mitsu Eclipse GSX
95 Mitsu Montero SR w/285/75/16 torsion bars cranked about 1.5"
04 Mitsu Lancer Ralliart
81 Datsun 280ZX
96 Dodge Cummins Turbo Diesel (316hp/815ft.lbs)
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: socalmonty] #518778 10/28/04 07:01 AM
Tag Offline
[img]Eddy Adams (Georgia[/img]
Didnt he have a silver Raider also. He dissapeared before Mitsutech and this forum came on line.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: Tag] #518779 10/28/04 02:51 PM
Mister Bishi Offline
I have a Gen 2 lwb 3.0 V6 with a 2" body lift and 2.5" suspension lift and run 34x11.5x15" Simex Jungle Trekkers these measure out to 34.6x11.9". No rubbing on the rear at all but if I fall into a hole and let the front wheels compress too hard they will rub slightly on the bottom of the guards. I have a 5sp with 4.88 diffs and it is at the limit as far as gearing goes. Never broke a front CV with these tyres even with a front Detroit locker fitted for 12 months. It is having 5.29 diff gears fitted now so that will restore on road driveability and eventually I will upgrade to 35x11.5x15" Simex Centipedes (measure out to 35.5x12.4x15").
I just luv my "clacker Jabber".................
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: Mister Bishi] #518780 10/28/04 10:32 PM
PartyTruck Offline
2" of bodylift, minimal cutting and no rub on 36x14.5x15. I'm now running 35" BFG AT's on 10" rims and it's perfect, almost no loss of power and gears feel more normal. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: PartyTruck] #518781 10/29/04 01:24 AM
35"12,5 BFG tires, no body lift, 2,5" suspension lift at the back ,torsion bars torqued and minimal cutting at the front, no rubbing and rides great
Kjarri
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? #518782 10/29/04 02:10 AM
cap510 Offline
2" body lift + 2.5" rear lift with torsion bar crank-up front 35x12.5x15 on 15x7 wheels
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: Mister Bishi] #518783 10/29/04 02:32 AM
Uhhh hate to rain you your parade Gen II guys but this guy has a Gen I. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Do any of you have trouble with your 33" tires? Can you fit 34/10.5/15 or would that be too big? [Re: triplediamonds] #518784 10/29/04 07:51 AM
8
85monteroS Offline
triple D's I run 34.9.50R15 swamper tsl's with no body lift and very minewt triming on the front opening of the front fenders I do have NEW cranked Tbars and S10 rear leaf springs though.they only rub offroad so far and it has been ok..only on the inner fender wells...these tires are on 6.5" or 7" rimsthough...depending on who'rim gauge you use???? yes they are positive offset like the stockers... i dont think the 10" ltb would clear on my truck!!!2" body lift though and it would be no problem..remeber this...NOTHING WHEELS LIKE A SWAMPER AND NOTHINGS STINKS ON THE ROAD AS BAD AS A SWAMPER!!!!! GOOD LUCK! <img src="/forums/images/graemlins/kewl.gif" alt="" />
85 monty swb,full 4.3swap,5spman&hd231tcase,34"swampers,dualbouncy, softop done,new tbars,S10 rear spring w/dual shackles.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6302 MB (Peak: 0.7410 MB) Data Comp: Off Server Time: 2026-06-07 03:17:43 UTC
