Replacing Oxygen sensor
#519282
10/28/04 10:01 PM
Is replacing the Oxygen sensor as easy as it looks? Turn a couple nuts, disconnect the wiring harness and pull out the old oxygen sensor. Reverse procedure to install new one.
Re: Replacing Oxygen sensor
[Re: sluggo]
#519283
10/28/04 10:35 PM
yup. the new OEM sensor comes with a new gasket. i'd buy two new nuts since they are a locking type.
nuts for oxy sensors (and for header piece drivers side) $1.48 90179-08059
if you have the right die, i'd clean up the threads on the studs and then use plenty of high temp (copper) anti-sieze.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
[Re: surlynkid]
#519284
10/29/04 02:47 PM
Chase the threads with a 8mm 1.25 die
1996 T100 Ext Cab 4x4 W/165k AMSOIL Throughout
[Re: Nathan]
#519285
10/29/04 03:48 PM
The oxygen sensor is ordered from Underdog Racing, which I understand is a supporting member of this forum, for about $86 delivered. Can't beat that. Also went to the local Ace Hardward and picked up a couple 8mm w/ 1.25 pitch stainless steel nuts & lock washers and picked up some anti-seize (copper) from NAPA.
I don't have an 8mm 1.25 die for cleaning the threads. Do you think that is necessary or will a bronze bristle brush and some anti-seize be good enough?
[Re: sluggo]
#519286
10/29/04 04:08 PM
Depends on your rust factor. You could could always use a new bolt working it back and forth with some spray lubricant to clean the threads if you have to. You'll probably be fine.
[Re: Nathan]
#519287
01/01/07 08:17 PM
I replaced my 2 Oxygen sensors today. The nuts were starting to disintegrate, but came off very easily with a little PB Blaster.
Toyota part # for Front Sensor- 89465-39835 (actual number on part is 89465-35360 Denso# 7900)
Toyota part # for Rear Sensor- 89465-39735 (actual number on part is 89465-35320 Denso # 7760)
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6108 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-05-29 23:44:13 UTCValid HTML 5 and Valid CSS
