Rebuild the trans or try to find a 'new' one? #519797 10/30/04 03:26 AM
Runner-Man Offline OP
Okay, here's the deal: 1989 4Runner, 22RE, W56 manual trans, 280,000 miles. 5th gear has developed a nice rythmic noise, which gets louder under power, and quietens down when you let off. Downshift into 4th, the noise is gone.
So, the question is, should I try to rebuild the trans, or try to find one in junkyard? Transmissions around here go for around $700-$900. I looked in the FSM, and the rebuild instructions require a lot of tools that I don't have (and there's a lot of parts in there, too!), stuff like pullers, and presses, etc. I'm fairly mechanically inclined, but I'm not sure how much parts would cost or if I can get them easily.
Advice?
Re: Rebuild the trans or try to find a 'new' one? [Re: Runner-Man] #519798 10/30/04 04:09 AM
kewlynx Offline
Might've answered your own question. Junkyard trannys here go for about what you pay for; rebuilds done locally are around $2K. Get in the Yellow Pages and shop around for a rebuild and warranty. Sounds like it's time for bearings.
Only problem with a junkyard tranny is there's no guarantee that you're getting anything better than what you're pulling, so....
**ubi apis- ibi salus**
Re: Rebuild the trans or try to find a 'new' one? [Re: Runner-Man] #519799 10/30/04 04:11 AM
kyle-22r Offline
i'd say it'd be good to be fairly adventurous if you want to rebuild your tranny.
have you looked into having marlin do it for you? for what a tranny goes for in your area, you can have a top notch "new" one for the same
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Rebuild the trans or try to find a 'new' one? [Re: kyle-22r] #519800 10/30/04 06:05 AM
Marlin Crawler does transmission rebuilds and we are much less than $2,000!
Our W56 rebuilds run between $799 - $849 depending on year.
We build the best manual Toyota transmissions and at a great price too!
See our transmission rebuilding page here:
http://www.marlincrawler.com/trans.html
Re: Rebuild the trans or try to find a 'new' one? #519801 10/30/04 06:09 AM
kewlynx Offline
FAWK. I needed to know this 2 years ago. <img src="/forums/images/graemlins/evil.gif" alt="" /> Figured you guys just did crawler stuff.
Re: Rebuild the trans or try to find a 'new' one? [Re: Runner-Man] #519802 10/30/04 06:44 PM
mine has been making the same noises for 30k
Re: Rebuild the trans or try to find a 'new' one? #519803 10/30/04 07:06 PM
Dok Offline
I got a rebuilt tranny from t&m trans exchange out in california for about $1000 including shipping. I wanted a marlin HD, but the lead time was around 6-8 weeks at that time (1.5 years ago). I've heard they now have them ready to roll though. Been very happy with my T&M so far.
Mine started with noise in 4th and later 2nd and soon after that I lost 4th and 2nd. I know some people go years with noises, but it was only about a month (~500mi) between noise and destruction in my case. Had to drive her with 3 gears for 5 hours through the mountains to my buddy's shop to do the replacement and the clutch started letting go 1/2way through the trip.
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: Rebuild the trans or try to find a 'new' one? [Re: Dok] #519804 11/01/04 03:57 PM
Red_Chili Offline
Toyota Section Staffer
You went here, right? Not very many specialty tools, not terribly difficult, and the press should be in your garage anyway. Nowadays Marlin is a good source for parts, except for a shim assortment (inexpensive dealer item, especially if they are ok with ordering an assortment, you use what you need and return the others - please check first with them as a courtesy - or make close friends with your local Toy tranny rebuilder).
If you do not feel up to it, Marlin is a good way to go.
-Bill
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6199 MB (Peak: 0.7181 MB) Data Comp: Off Server Time: 2026-05-29 16:14:29 UTC
