New radiator #520476 11/01/04 06:13 AM
Toybluggie Offline OP
I finally got around to replacing my timing cover (thanks for the good writeups <img src="/forums/images/graemlins/smile.gif" alt="" />) and I noticed that my radiator is is need of replacing. What are my options other than stock? Thanks in advance. <img src="/forums/images/graemlins/patriot.gif" alt="" />
JT
84 22re pickup
Re: New radiator [Re: Toybluggie] #520477 11/01/04 06:18 AM
Kaptain Offline
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: New radiator [Re: Toybluggie] #520478 11/01/04 08:33 AM
kewlynx Offline
NAPA carries Modine; haven't had trouble with them. Main thing is to mix your antifreeze with DISTILLED water, so things don't corrode on you; do a flush before you change it out to descale the system. MAKE SURE the heater is turned on, so the core can be flushed too.
When you service it back up, also MAKE SURE the heater is on; leave the radiator cap off and let it run. This burps all the air out of the system, so you don't experience an overheat condition afterward. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5951 MB (Peak: 0.6481 MB) Data Comp: Off Server Time: 2026-06-07 05:01:48 UTC
