Downey Cable Locker Conversion Kit #520599 11/01/04 05:21 PM
V
Vermonster Offline OP
The factory locker on my 97 4Runner appears to have crapped out. I'm going to try a rebuild, but am not hopeful. Unless I can find a good condition used actuator at a junk yard, I'll be lockerless as I don't have $750 for the part.
I see Downey makes a cable conversion. I wonder if anyone has tried this. If so, how difficult is the install? How reliable? What was your impression of the build quality on the product?
Thanks
George
Re: Downey Cable Locker Conversion Kit [Re: Vermonster] #520600 11/01/04 06:13 PM
anthony1 Offline
I got one of those. I like it. I had to work with them to get the parts to fit right. They're made of aluminum so it won't rust.
The most dificult part I find is to allign everything up so it will move easily with the cable.
I modify it so you don't have to keep pushing it to lock. I put a spring in there so it will push in when it sync up. I also have a pvc tube to hold it in unlock position on the other end.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Downey Cable Locker Conversion Kit [Re: Vermonster] #520601 11/02/04 07:19 PM
V
Thanks. Anybody else with thoughts?
Re: Downey Cable Locker Conversion Kit [Re: Vermonster] #520602 11/02/04 07:44 PM
John Smith Offline
With the exception of the poster above all I have ever read is people calling the kit a waste of money. Why pay for something if you have to work as hard as the guy above to make it work. I will fab it myself thank you.
John Smith 79 FJ40
87 StdCab w/22R TLCA# 9074
Re: Downey Cable Locker Conversion Kit [Re: Vermonster] #520603 11/03/04 04:08 AM
Winch Offline
Are you sure it's the locker, and not a fuse, switch or wiring problem? What do you mean crapped out?
'02 Double cab, 5 speed swap, dual T-cases, FZJ80 SAS, E-lockers F/R, 37" MTR's
http://winchstoyotaparts.yolasite.com/
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6069 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-11-16 01:17:23 UTC
