When Mitsu has a good idea, why do they only use it sometimes? #521258 11/03/04 12:52 AM
TobyB Offline OP
So pulling the crank timing belt pulley... what a PITA! The pulley was well and truly rusted on, and took a good bit of tug to get it off.
I finally resorted to drilling and tapping it, since no puller within 50 miles of the truck would squeeze behind the thing. And I wanted to save the pump housing...
Of course, in drilling it, the bit overran and cut the crank's sealing surface for the oil seal- good thing this motor's toast, or I'd be REALLY pissed. Lesson- use a drill stop!
Now, the rear brake drums are already drilled and tapped- why couldn't they do the same thing here? It doesn't take genius, people!
Grump.
Toby
'89 V6 4dr- '4- Doris'
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: TobyB] #521259 11/03/04 01:27 AM
LRJ4x4 Offline
Ever work on a ford taurus, I can't find the website now, most likly Ford sued him. He documented with a digital camera all the manufacturing and engineering defects in a Taurus.
here is a funny site anyways
http://www.fordlemon.com/WEBSITE_netscape/intro.html
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: LRJ4x4] #521260 11/03/04 01:31 AM
A
AcidophilusRex Offline
I traded-in a Taurus with half the mileage to get my Montero, mainly because all the things I was finding wrong with the Taurus were scaring the crap out of me.
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: AcidophilusRex] #521261 11/03/04 02:26 AM
DougH Offline
Mitsubishi Forum Moderator
Hey at least they have a nice electric fan. <img src="/forums/images/graemlins/smile.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: TobyB] #521262 11/03/04 03:27 AM
The belt sprocket is powdered metal, not a cast or machined piece, and is just metal dust that's been squdged together and doesn't have any real tensile strength, so using a puller that uses tapped holes, a la a chevy steering wheel puller or harmonic balancer puller is iffy, and the part is compromised (a paper weight) anyway after you get it off. Just dremel a slot in the sprocket, and drive in a wedge, and the two parts come off quite easily. Then you can dress up the crank nose with fine emery paper, and use antiseize so it comes off easy next time.
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: TobyB] #521263 11/03/04 04:09 PM
BobShaw Offline
If I remember corrrect (I'm getting older) there was something bolted to the harmonic ballancer and you use these drilled holes with jack screw to remove the pulley. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Nothing is difficult on a Japanese car. You need to know the trick.
Bob Shaw
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: DougH] #521264 11/03/04 04:38 PM
NathanC Offline
Yeah, I grabbed one of those and a 130amp alternator from one recently <img src="/forums/images/graemlins/smile.gif" alt="" />
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: BobShaw] #521265 11/03/04 11:48 PM
TobyB Offline OP
naw, I'm talking about the cam belt pulley behind it. Little, solid gear- toothed thing.
And if 2- 6mm holes 'compromise' that thing, well, it was a POS to begin with! But I'm not planning on reusing it- the other engine's was in better shape.
t
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: LRJ4x4] #521266 11/04/04 06:44 AM
a crown vic is a much better car... even better gas milage..besides the standard V8
Re: When Mitsu has a good idea, why do they only use it sometimes? [Re: LRJ4x4] #521267 11/04/04 07:40 AM
52degrees Offline
I work at a General Motors dealership and I can promise you that you wouldn't believe the safety defects that are allowed to continue in production for years AFTER A RECALL CAMPAIGN HAS BEEN ISSUED!
There is a recall for "N" body cars that they call "Thermal Events." This is code for [color:"red"] [/color] CAR FIRE!
[color:"black"] [/color]
For as long as I can remember, we have been fixing these cars by installing a relay in the ignition circuit. I think the first one was in 1998. 2003 models now need the same thing... DUH!
DUMB- <img src="/forums/images/graemlins/butwiggle.gif" alt="" />'S
KG6VNX
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6322 MB (Peak: 0.7400 MB) Data Comp: Off Server Time: 2026-11-02 04:00:41 UTC
